Hi!
We have an on-premise keycloak with an Nginx and it works correctly.
We have moved the configuration to AWS and it does not work for us. It gives us the following issue:
log:
05.dic-11:04:42,892 [Opensat] ERROR org.keycloak.adapters.OAuthRequestAuthenticator - failed to turn code into token
java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(SocketInputStream.java:196)
at java.net.SocketInputStream.read(SocketInputStream.java:122)
at sun.security.ssl.InputRecord.readFully(InputRecord.java:442)
at sun.security.ssl.InputRecord.read(InputRecord.java:480)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:934)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1332)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1359)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1343)
at org.apache.http.conn.ssl.SSLSocketFactory.createLayeredSocket(SSLSocketFactory.java:573)
at org.keycloak.adapters.SniSSLSocketFactory.createLayeredSocket(SniSSLSocketFactory.java:114)
at org.apache.http.conn.ssl.SSLSocketFactory.connectSocket(SSLSocketFactory.java:557)
at org.keycloak.adapters.SniSSLSocketFactory.connectSocket(SniSSLSocketFactory.java:109)
at org.apache.http.conn.ssl.SSLSocketFactory.connectSocket(SSLSocketFactory.java:414)
at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:180)
at org.apache.http.impl.conn.AbstractPoolEntry.open(AbstractPoolEntry.java:144)
at org.apache.http.impl.conn.AbstractPooledConnAdapter.open(AbstractPooledConnAdapter.java:134)
at org.apache.http.impl.client.DefaultRequestDirector.tryConnect(DefaultRequestDirector.java:610)
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:445)
at org.apache.http.impl.client.AbstractHttpClient.doExecute(AbstractHttpClient.java:835)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:108)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:56)
at org.keycloak.adapters.ServerRequest.invokeAccessCodeToToken(ServerRequest.java:111)
at org.keycloak.adapters.OAuthRequestAuthenticator.resolveCode(OAuthRequestAuthenticator.java:335)
at org.keycloak.adapters.OAuthRequestAuthenticator.authenticate(OAuthRequestAuthenticator.java:280)
at org.keycloak.adapters.RequestAuthenticator.authenticate(RequestAuthenticator.java:139)
at org.keycloak.adapters.servlet.KeycloakOIDCFilter.doFilter(KeycloakOIDCFilter.java:195)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:110)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:498)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:169)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:1025)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:445)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1115)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:637)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
Niginx Config:
upstream keycloak {
ip_hash;
server 172.31.9.74:8081 max_fails=1 fail_timeout=60s;
server 172.31.9.74:8082 max_fails=1 fail_timeout=60s;
keepalive 32;
server {
listen 80;
server_name _midomain.com;
access_log /var/log/nginx/access.midomain.com.log;
error_log /var/log/nginx/error.midomain.com.log;
location /.well-known {
alias /usr/share/nginx/html/_midomain.com/.well-known;
return 301 https://_midomain.com$request_uri;
server {
listen 443 ssl http2;
server_name _midomain.com ssl-_midomain.com;
server_tokens off;
ssl_certificate /opt/certificates/certificado.crt;
ssl_certificate_key /opt/certificates/certificado.key;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_prefer_server_ciphers on;
access_log /var/log/nginx/access._midomain.com;
error_log /var/log/nginx/error._midomain.com;
proxy_hide_header Cache-Control;
proxy_hide_header Pragma;
location /favicon.ico {
internal;
location / {
proxy_set_header Host midomain.com;
proxy_set_header X-Forwarded-Port 443;
proxy_next_upstream error timeout invalid_header http_500;
proxy_connect_timeout 2;
proxy_pass http://keycloak;
location /auth {
proxy_pass http://keycloak/auth;
proxy_redirect off;
proxy_set_header Host $host;
We think that we have followed all the configuration instructions of the headers.
Could you help us, please?
