I’m running a docker integrated keycloak instance with MariaDB storage backend.
As I would like to be able to rebuild my config from scratch, I’m trying to setup an automated keycloak full data export through command line.
I use command from documentation page Export and Import
docker exec -it keycloak /opt/jboss/keycloak/bin/standalone.sh -Djboss.socket.binding.port-offset=100 -Dkeycloak.migration.action=export -Dkeycloak.migration.provider=singleFile -Dkeycloak.migration.realmName=clusters -Dkeycloak.migration.usersExportStrategy=REALM_FILE -Dkeycloak.migration.file=/opt/jboss/keycloak/standalone/data/backup/dump.json
The issue is that it fail, due to the error message below :
Caused by: java.sql.SQLException: Access denied for user ‘admin’@‘10.11.0.50’ (using password: YES)
Current charset is US-ASCII. If password has been set using other charset, consider using option ‘passwordCharacterEncoding’
As my password has been set using latin1
charset, I would like to set passwordCharacterEncoding
Question : Is there any option to set passwordCharacterEncoding
through cli ?
Thanks.
