I want to add functionality to the core addUser
and removeUser
functions. From what I understand, I can write a new UserStorageProvider
in order to allow federation with other platforms. That’s not what I want to do, though - I want to add some extra code that runs when the built-in addUser
and removeUser
functions are called. Is there a way to do this with the SPI or extensions?
There aren’t great ways to do this that I’m aware of. It has been proposed to have a better event model for these types of changes, but I don’t know where they are in development.
You can execute code on user removed by registering a ProviderEventListener
in the KeycloakSessionFactory
. E.g.:
@Override
public void postInit(KeycloakSessionFactory factory) {
factory.register(
(event) -> {
if (event instanceof UserModel.UserRemovedEvent) {
// do your handler here
For user added, you can write an EventListener
that watches the REGISTER
event, but that won’t catch all of the cases (e.g. an admin adds a user through the admin UI). You’d also have to watch for admin events for CREATE
on UserResource
, but I’m not sure if those two would be comprehensive.
Perfect! Thank you, @xgp - it took me a little while to remember my Java, but once I did, this worked like a charm!
