I’m trying to port my plugins to Keycloak 17, and after adding a plugin for the LoginFormsProviderFactory keycloak starts up but it can’t open the administration console. The only exception that we have is a NullPointerException at AuthorizationEndpointBase::createAuthenticationSession while getting the LoginsFormProvider:
session.getProvider(LoginFormsProvider.class).setAuthenticationSession(authSession);
I’ve removed any external dependencies from my plugin to avoid problems with class loader.
If I remove this LoginFormsProvider plugin and leave all the others it works fine.
Follows the stacktrace:
2022-03-03 12:11:56,729 ERROR [org.keycloak.services.error.KeycloakErrorHandler] (executor-thread-0) Uncaught server error: java.lang.NullPointerException
at org.keycloak.protocol.AuthorizationEndpointBase.createAuthenticationSession(AuthorizationEndpointBase.java:209)
at org.keycloak.protocol.oidc.endpoints.AuthorizationEndpoint.process(AuthorizationEndpoint.java:178)
at org.keycloak.protocol.oidc.endpoints.AuthorizationEndpoint.buildGet(AuthorizationEndpoint.java:112)
at io.quarkus.vertx.http.runtime.VertxHttpRecorder$5.handle(VertxHttpRecorder.java:362)
at io.quarkus.vertx.http.runtime.VertxHttpRecorder$5.handle(VertxHttpRecorder.java:340)
at org.keycloak.quarkus.runtime.integration.web.QuarkusRequestFilter.lambda$createBlockingHandler$1(QuarkusRequestFilter.java:66)
Any tip to figure out / debug what I might be doing wrong?
Thanks for the help
