Hello!
I’m currently trying to use keycloak as a SAML identity provider for nextcloud (everything is hosted by me).
I tried to follow the instruction found there : Janik Vonrotz - Configure SAML Authentication for Nextcloud with Keycloack but it seems that some field are missing, I can’t find the " Client SAML Endpoint" in keycloak…
I’m hosting both nextcloud and keycloak using kubernetes (k3s) using respectively tags “stable” and “latest”.
Since the blog post is from almost three years ago, I’m guessing a lot has changed since then, can you help me figure out what ?
Thanks a lot !
