I have Keycloak “standalone” deployed using docker [keycloak:12.0.4] connected to postgres [postgres:13.2]
Recently I’m getting this error frequently and randomly and users will be locked out from Keycloak until we restart the keycloak container. I would like to know what is the root cause for this issue so I can handle it properly.
This happens just during normal operation we didn’t restart or upgrade keycloak prior to this issue.
Logs:
**"Keycloak" SQL Error: 0, SQLState: null ERROR [org.hibernate.engine.jdbc.spi.SqlExceptionHelper] (default task-388) javax.resource.ResourceException: Unable to get managed connection for java:jboss/datasources/KeycloakDS [org.hibernate.event.internal.DefaultLoadEventListener] Error performing load command : org.hibernate.exception.GenericJDBCException: Unable to acquire JDBC Connection.**
the Datasources block in standalone.xml:
<datasources>
<datasource jndi-name="java:jboss/datasources/ExampleDS" pool-name="ExampleDS" enabled="true" use-java-context="true" statistics-enabled="${wildfly.datasources.statistics-enabled:${wildfly.statistics-enabled:false}}">
<connection-url>jdbc:h2:mem:test;DB_CLOSE_DELAY=-1;DB_CLOSE_ON_EXIT=FALSE</connection-url>
<driver>h2</driver>
<security>
<user-name>user</user-name>
<password>pass</password>
</security>
</datasource>
<datasource jndi-name="java:jboss/datasources/KeycloakDS" pool-name="KeycloakDS" enabled="true" use-java-context="true" use-ccm="true">
<connection-url>jdbc:postgresql://${env.DB_ADDR:postgres}/${env.DB_DATABASE:keycloak}${env.JDBC_PARAMS:}</connection-url>
<driver>postgresql</driver>
<pool>
<flush-strategy>IdleConnections</flush-strategy>
</pool>
<security>
<user-name>${env.DB_USER:user}</user-name>
<password>${env.DB_PASSWORD:pass}</password>
</security>
<validation>
<check-valid-connection-sql>SELECT 1</check-valid-connection-sql>
<background-validation>true</background-validation>
<background-validation-millis>60000</background-validation-millis>
</validation>
</datasource>
<drivers>
<driver name="h2" module="com.h2database.h2">
<xa-datasource-class>org.h2.jdbcx.JdbcDataSource</xa-datasource-class>
</driver>
<driver name="postgresql" module="org.postgresql.jdbc">
<xa-datasource-class>org.postgresql.xa.PGXADataSource</xa-datasource-class>
</driver>
</drivers>
</datasources>
Any idea what should be changed and how to resolve this?
Thanks
