Fresh Keycloak 25.0.1: No Username / PW for master realm
Hi!
I recently wanted to migrate a working instance of a KC 24.0.5 Docker-Deployment to KC 25.0.1
However, when I tried to log into the master realm after it finished starting I got a series of unfinished HTML-Pages.
“RESOURCE NOT FOUND”
a neverending “Loading Administration Console”
The only error I see in the console is a weird error message about disallowed mime-types:
The only thing I changed in my docker config was the version number and the keycloak parameters “hostname” and “hostname-admin”, which no longer have an “-url” attached.
I am not sure what is causing this behaviour since I wiped the database so it should be a clean new install of KC.
Has anyone experienced simililar problems before?
Thank you for any advice you can give.
Kind regards
Ollowain
UPDATE:
Upon further study, I noticed that the keycloak container seems to be missing a ressource file from the keycloak.v2 admin theme:
404: /resources/cxkn4/admin/keycloak.v2/assets/main-BeZMleLO.js
Could that explain the above mentioned behaviour and how would i go about fixing it?
Regards
FSeifer
UPDATE:
I solved the issue!
Should anybody else run into his issue, I finally realized that I had been using Port 9000 for the keycloak http endpoint.
via http-port=9000
Turns out since Keycloak 25 the Port 9000 is used as the default port of the management interface
see: Release Notes
After switching the http-port from 9000 back to 8080 all worked as expected.
Although I am surprised that the server startet in the first place while the front-end port and the management port were identical. Seems worth a bug ticket.
Regards
Ollowain
