High CPU Utilization and Frequent Restarts after Upgrading from Keycloak 19 to Keycloak 22
We recently upgraded from Keycloak 19 to Keycloak 22 and have observed significant performance degradation in our system. Specifically, CPU utilization has spiked to 90% under normal load. Our setup includes a 2-node cluster running in ECS Fargate, and we’ve been experiencing frequent container restarts due to the error: Terminating due to java.lang.OutOfMemoryError: Java heap space.
Here are the steps we’ve taken to address the issue:
  1. Increased Heap Space: We adjusted the initial and maximum memory settings using the following parameters:
-Xms1024m -Xmx3072m
However, this did not resolve the issue. The high CPU consumption and container restarts persisted.
  1. Memory Management Adjustments: We noticed changes in memory management parameters in the Keycloak 24 kc.sh file and applied similar settings to our Keycloak 22 image:
-XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20 -XX:MaxRAMPercentage=70 -XX:MinRAMPercentage=70 -XX:InitialRAMPercentage=50
Unfortunately, these adjustments also did not mitigate the problem. The CPU usage remained high, and the container continued to restart.
  1. Heap Dump Analysis: We enabled heap dumps on OutOfMemoryError by setting -XX:+HeapDumpOnOutOfMemoryError and analyzed the heap dumps using Eclipse Memory Analyzer. Our analysis indicated that Freemarker is consuming most of the memory.
Attached are the logs and screenshots from the Eclipse Memory Analyzer for your reference.
Class Name        | Shallow Heap |  Retained Heap | Percentage
io.vertx.core.impl.VertxThread @ 0x69c3c4710  executor-thread-8 Thread                           |          136 | 1,16,72,22,944 |     31.68%
'- <Java Local> freemarker.core.Environment @ 0x69c6aaf18                                        |          296 |   49,05,33,824 |     13.31%
   '- currentMacroContext freemarker.core.Macro$Context @ 0x69c6b0d98                            |           48 |   49,04,93,592 |     13.31%
      '- localVars freemarker.core.Environment$Namespace @ 0x69c6b4230                           |           40 |   49,04,93,544 |     13.31%
         '- map java.util.HashMap @ 0x69c6b4258                                                  |           48 |   49,04,93,504 |     13.31%
            '- table java.util.HashMap$Node[16] @ 0x69c6b4288                                    |           80 |   49,04,93,456 |     13.31%
               |- [4] java.util.HashMap$Node @ 0x69c6b4378                                       |           32 |   49,04,85,912 |     13.31%
               |  '- value freemarker.core.AddConcatExpression$ConcatenatedSequence @ 0x76a445f70|           24 |   49,04,85,880 |     13.31%
               |- [6] java.util.HashMap$Node @ 0x69c6b4358                                       |           32 |          7,104 |      0.00%
               |- [1] java.util.HashMap$Node @ 0x69c6b6998                                       |           32 |            128 |      0.00%
               |- [8] java.util.HashMap$Node @ 0x69c6b4338                                       |           32 |            104 |      0.00%
               |- [15] java.util.HashMap$Node @ 0x69c6b42d8                                      |           32 |             32 |      0.00%
               |- [11] java.util.HashMap$Node @ 0x69c6b42f8                                      |           32 |             32 |      0.00%
               |- [10] java.util.HashMap$Node @ 0x69c6b4318                                      |           32 |             32 |      0.00%
               |- [0] java.util.HashMap$Node @ 0x69c6b69b8                                       |           32 |             32 |      0.00%
               '- Total: 8 entries                                                               |              |                |
We would greatly appreciate any insights or suggestions on how to address these issues. Has anyone else experienced similar problems after upgrading to Keycloak 22? Are there specific configurations or optimizations that we might be missing?
