Hostname Configuration for Quarkus Load-balancing Setup
I am new to advanced keycloak configuration, have been using keycloak WildFly distribution as a single instance for my project without any problem.
For WildFly distribution, there are lots of documents and topics about Keycloak Clusters. However, I couldn’t find much about Quarkus distribution. I need a shared database cluster setup for failover senarios. I use this as cache-ispn.xml(JDBC_PING): Keycloak 17 example using JGroups JDBC_PING discovery protocol for Infinispan · GitHub
I am trying the following setup and couldn’t even achieve reverse proxy settings.
Could you please help on the configuration(or please suggest better way). My approach can be wrong, I am not sure about it.
For now, using Docker and Kubernetes is not an option.
Server 1: kyc.serverdomain
NGINX Loadbalancing (I know round robin is not a good option, just trying to make it work for now)
Note: Connection should be secure to other servers.
Nginx Conf:
server {
        listen 80;
        listen [::]:80;
        server_name kyc.example.com;
        return 302 https://$server_name$request_uri;
upstream keycloak-cluster {
       server kyc1.example.com;
       server kyc2.example.com;
server {
        listen 443 ssl http2;
        listen [::]:443 ssl http2;
        location / {
                proxy_set_header Host $host;
                proxy_pass https://keycloak-cluster;
    ssl_certificate /etc/letsencrypt/live/kyc.example.com/fullchain.pem;
    ssl_certificate_key /etc/letsencrypt/live/kyc.example.com/privkey.pem;
Server 2: kyc1.serverdomain
Keycloak Instance 1
Nginx Conf:
server {
        server_name kyc1.example.com;
server {
    listen [::]:443 ssl ipv6only=on;
    listen 443 ssl;
    ssl_certificate /etc/letsencrypt/live/kyc1.example.com/fullchain.pem;
    ssl_certificate_key /etc/letsencrypt/live/kyc1.example.com/privkey.pem;
    include /etc/letsencrypt/options-ssl-nginx.conf;
    ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
    location / {
                proxy_pass          https://0.0.0.0:8443/;
                proxy_http_version  1.1;
                proxy_set_header    Host $server_name:$server_port;
                proxy_set_header    X-Forwarded-Host $http_host;
                proxy_set_header    X-Forwarded-For $remote_addr;
Keycloak Conf:
db=postgres
db-username=db_user_1
db-password=password
db-url=jdbc:postgresql://postgresql.example.com/keycloak_cluster_db
https-certificate-file=/etc/letsencrypt/live/kyc1.example.com/cert.pem
https-certificate-key-file=/etc/letsencrypt/live/kyc1.example.com/privkey.pem
proxy=edge
hostname=kyc.example.com **# Not sure if hostname is correct, if I change it to kyc1.example.com works well in a single instance**
https-port=8443
hostname-strict-backchannel=true
Server 3: kyc2.serverdomain
Keycloak Instance 2
Configuration is the same except the domain is kyc2.serverdomain
Server 4: PostgreSQL
Shared database for both instances
