I’m developing an extension to keycloak to add some capabilities and extendind the jpa domain. So far so good, I’m strugling with my custom rest-api. Some of my objects uses LocalDateTime object and it is causing an error when jackson tryies to serialize the representation object.
According to the stack trace, to fix that I need to just add an jsr310 jackson module in the ObjectMapper instance, but I’ve not found any clue to where configure this inside my extension.
Uncaught server error: com.fasterxml.jackson.databind.exc.InvalidDefinitionException: Java 8 date/time type `java.time.LocalDateTime` not supported by default: add Module "com.fasterxml.jackson.datatype:jackson-datatype-jsr310" to enable handling (through reference chain: br.com.becomex.beconnect.spi.company.CompanyModel["created"])
Searching in the keycloack source code I found the org.keycloak.services.util.ObjectMapperResolver
and I guess I could just create another one to replace this, but I do not want to mess with keycloak default objects.
Can someone help me to add and register the jsr310 module on keycloak 20 extension?
