How can I connect to bearer-only client with SSL?
Hi there,
I’m developing 2 services(keycloak clients). One for UI(credential) and another for REST API(bearer-only). I have tested without SSL and they’ve worked fine till now. But if I wanted to apply SSL on my REST API(using self-signed cert), what should I do? ‘KeycloakRestTemplate’ makes exception with message like this:
java.lang.IllegalStateException: Cannot set authorization header because Authentication is of type class org.springframework.security.authentication.AnonymousAuthenticationToken but class org.keycloak.adapters.springsecurity.token.KeycloakAuthenticationToken is required
Then I tried some code snippet that I used for non-OAuth2 REST API, but same result
SSLContext context;
try {
    TrustStrategy acceptingTrustStrategy = new TrustSelfSignedStrategy();
    context = SSLContexts.custom()
        .setProtocol("TLS")
        .loadTrustMaterial(null, acceptingTrustStrategy)
        .build();
    context.init(
        null,
        new TrustManager[] { new X509TrustManager() {
            public void checkClientTrusted(X509Certificate[] arg0, String arg1) throws CertificateException {}
            public void checkServerTrusted(X509Certificate[] arg0, String arg1) throws CertificateException {}
            public X509Certificate[] getAcceptedIssuers() { return new X509Certificate[0]; }
    new java.security.SecureRandom());
} catch(Exception e) {
    System.err.println(e);
    return	null;
SSLConnectionSocketFactory scsf = new SSLConnectionSocketFactory(context, NoopHostnameVerifier.INSTANCE);
KeycloakClientRequestFactory factory = new KeycloakClientRequestFactory();
factory.setReadTimeout(5000);
factory.setConnectTimeout(3000);
CloseableHttpClient httpClient = HttpClientBuilder.create()
    .setMaxConnTotal(100)
    .setMaxConnPerRoute(5)
    .setSSLContext(context)
    .setSSLSocketFactory(scsf)
    .build();
factory.setHttpClient(httpClient);
KeycloakRestTemplate restTemplate = new KeycloakRestTemplate(factory);
ResponseEntity<String[]> response = restTemplate.getForEntity(serviceUrl, String[].class);
