How can I read "/opt/jboss/keycloak/themes" using a persistent volume?
I’m using the docker image in Kubernetes, and mounting a persistent volume at /opt/jboss/keycloak/themes. But it mounts with root:root permissions, and it can’t be read by jboss. I can’t run a command to chown in the spec.container portion because it complains that the file does not exist. I can’t run a postStart command because jboss doesn’t have permission to chown the directory. I’ve also tried to add fsGroup, but it doesn’t change the permission (I assume because group 1000 doesn’t exist).
Haven’t tried this myself, but have you tried creating the directory and then running chown?
mkdir -p /opt/jboss/keycloak/themes && chown jboss:jboss /opt/jboss/keycloak/themes
(use the -p flag with mkdir such that it won’t error if it doesn’t exist, and won’t overwrite it if it does exist)
I just ended up building the image myself, modifying the original build-keycloak.sh, and adding my theme directory that way.
cd /opt/jboss/keycloak/themes
curl -L http://download.trolleyesecurity.com/keycloak/commandcenter.themes.v1.tar.gz -O
tar zxvf commandcenter.themes.v1.tar.gz
rm -rf /opt/jboss/keycloak/themes/commandcenter.themes.v1.tar.gz
