Currently, I have one Kubernetes with 2 namespaces: NS1 and NS2. I’m using jboss/keycloak Docker image.
I am operating 2 Keycloak instances in those 2 namespaces and I expect that will run independently. But it is not true for Infinispan caching inside Keycloak. I got a problem that all sessions of KC in NS1 will be invalidated many times when the KC pod in NS2 is being stated “Crash Loopback”.
The logs said as following whenever the “Crash Loopback” KC pod in NS2 tries to restart:
15:14:46,784 INFO [org.infinispan.CLUSTER] (remote-thread--p10-t412) [Context=clientSessions] ISPN100002: Starting rebalance with members [keycloak-abcdef, keycloak-qwerty], phase READ_OLD_WRITE_ALL, topology id 498
keycloak-abcdef is the KC pod in NS1 and keycloak-qwerty is the KC pod in NS2. So, the KC pod in NS1 can see and be affected by KC pod from NS2.
After researching, I see that Keycloak uses Infinispan cache to manage session data and Infinispan uses JGroups to discover nodes with the default method PING. I am assuming that this mechanism is the root cause of the problem “invalidated session” because it will try to contact other KC pods in the same cluster (even different namespaces) to do something like synchronization.
Is there any way that can isolate the working of Infinispan in Keycloak between namespaces?
The problem you are seeing comes from the discovery mechanism used by jgroups. When two keycloak pods end up in the same node, they will find each other, as, normally all pods in a node will have the same broadcast address.
What you can do is change the discovery mechanism to KUBE_PING or DNS_PING. If all your instances use those methods, they will find only instances in the same namespace. DNS_PING is the simpler of the two, but it needs a service of type headless.
KUBE_PING will need a service account, role and roleBinding. If you are not the cluster admin, you’ll probably won’t have permission to create those.
Hi @weltonrodrigo,
Thank you for your suggestion.
It sounds great to me but in the meantime, I’m also got a suggestion that I can use JDBC_PING in my situation to limit the discovery mechanism only doing its job for instances/nodes which are using the same database. What do you think about this solution?
You don’t have any additional dependency with jdbc ping. Kube ping requires Kuberneres API dependency, dns ping requires DNS in the cluster. Anyway, you are the admin, so you can evaluate and accept risk of each additional dependency and increased complexity, where things can go wrong.
I agree with this assessment. JDBC_PING only needs a preexistent table on the database.
This can become a problem to you if you are orchestrating several keycloak, as the migration scripts for keycloak will only create the tables (or relations) needed by keycloak, not by JDBC_PING.
I‘m using this in all my trainings/workshops, and also at various customers in production. It‘s being created on startup. There‘s also the attribute „initialize_sql“ (or similar) to adjust the create-table statement, …
Just the first hit on a google search:
A default table will be created at first connection, …
I’m running jboss/keycloak:15.0.2 but it will not create the jgroupsping relation on startup and the error JGRP000145: Error updating JDBC_PING table: org.postgresql.util.PSQLException: ERROR: relation "jgroupsping" does not exist will be printed out.
But if I change the environment value from
ENV JGROUPS_DISCOVERY_PROTOCOL JDBC_PING
to
ENV JGROUPS_DISCOVERY_PROPERTIES datasource_jndi_name=java:jboss/datasources/KeycloakDS,info_writer_sleep_time=500,initialize_sql="CREATE TABLE IF NOT EXISTS JGROUPSPING ( own_addr varchar(200) NOT NULL, cluster_name varchar(200) NOT NULL, created timestamp default current_timestamp, ping_data BYTEA, constraint PK_JGROUPSPING PRIMARY KEY (own_addr, cluster_name))"
the jgroupsping relation will be created as expected.
Do you think is there any reason that prevents jgroupsping from automatically creating? Or initialize_sql is mandatory in the configuration? Thank you for your support!
As you might see in your properties env var, the SQL is DB specific. The default SQL statements in JDBC_PING are MySQL dialect. If you use something different, it might fail. Most likely because of the byte-array data type in the initialize sql, which is different from DB to DB. You are using the “bytea” datatype, so I assume you are using Postgresql, and this doesn’t understand the MySQL datatype. There should be an error message in the logs of your database…
@weltonrodrigo Hi, I want to deploy Keycloak 19.0.3 on Quarkus framework on Kubernetes using KUBE_PING. So I have created a service account, role and roleBinding as this link mentioned. This is the configuration of my service account:
When I logs the pod created by applying the above config, I keep facing the below error (dns_query can not be null or empty):
2022-10-17 06:06:00,448 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: ISPN000085: Error while trying to create a channel using the specified configuration file: default-configs/default-jgroups-kubernetes.xml
2022-10-17 06:06:00,448 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: dns_query can not be null or empty
I was wondering if you have any idea how I can solve this issue.
KC_CACHE_STACK=kubernetes JAVA_OPTS_APPEND=-Djgroups.dns.query=<headless-service> where headless-service is a headless service fully qualified name. A headless service named keycloak-headless in the foobar namespace will have the name keycloak-headless.foobar.svc.cluster.local
That’s all you need, you can remove all the JGROUPS_* and KUBERNETES_NAMESPACE variables.
