I’m working with an very old VB.net application trying to layer in SSO auth using OWIN and KeyCloak. This is all new to me. The approach I’m taking is to create a C# app to sit in between KeyCloak and my VB app. I’ve been able to get my C# app to open the login screen of KeyCloak, authenticate and return to the C# app or even the VB app. This seems fine.
However, I need the id_token and username to pass to the VB app. When using Fiddler I can see KeyCloak is generating a post back to my return page with the id_token in tow. However, it is on another thread and gets redirected to the original page but without the id_token. I must be missing something. I’ve seen code where there are notifications wired and I think they should grab the token and user info, but I don’t know how to get the notifications to work. There is no explicit documentation to tell me what to do.
Am I supposed to have a listener to catch the post from KeyCloak? If so can some one show me how to create one?
Note : I’ve found some Microsoft code using OWIN and Azure and MVC that bring back user info. However, I point this same code to KeyCloak it authenticates but no user info is returned.
Any help will be greatly appreciated.
-Thanks
In my Startup.cs file I have the following (I’ve tried many different variations to no avail):
public void ConfigureAuth(IAppBuilder app)
app.SetDefaultSignInAsAuthenticationType(CookieAuthenticationDefaults.AuthenticationType);
app.UseCookieAuthentication(new CookieAuthenticationOptions());
app.UseOpenIdConnectAuthentication(
new OpenIdConnectAuthenticationOptions
// Sets the ClientId, authority, RedirectUri as obtained from web.config
ClientId = _clientId,
ClientSecret = _clientSecret,
RequireHttpsMetadata = false,
Authority = _authority,
RedirectUri = _redirectUri,
// PostLogoutRedirectUri is the page that users will be redirected to after sign-out. In this case, it is using the home page
PostLogoutRedirectUri = _redirectUri,
Scope = OpenIdConnectScope.OpenIdProfile,
// ResponseType is set to request the id_token - which contains basic information about the signed-in user
ResponseType = OpenIdConnectResponseType.IdToken,
// ValidateIssuer set to false to allow personal and work accounts from any organization to sign in to your application
// To only allow users from a single organizations, set ValidateIssuer to true and 'tenant' setting in web.config to the tenant name
// To allow users from only a list of specific organizations, set ValidateIssuer to true and use ValidIssuers parameter
TokenValidationParameters = new TokenValidationParameters()
ValidateIssuer = true
// OpenIdConnectAuthenticationNotifications configures OWIN to send notification of failed authentications to OnAuthenticationFailed method
Notifications = new OpenIdConnectAuthenticationNotifications
AuthenticationFailed = OnAuthenticationFailed,
SecurityTokenReceived = OnSecurityTokenReceived
Also tried:
app.UseExternalSignInCookie(DefaultAuthenticationTypes.ExternalCookie);
app.UseOpenIdConnectAuthentication(new OpenIdConnectAuthenticationOptions
ResponseType = OpenIdConnectResponseType.CodeIdToken,
//MetadataAddress = $"{_authority}/.well-known/openid-configuration",
TokenValidationParameters = new TokenValidationParameters { NameClaimType = "name" },
AuthorizationCodeReceived = async n =>
var client = new HttpClient();
var tokenResponse = await client.RequestAuthorizationCodeTokenAsync(new AuthorizationCodeTokenRequest
Address = $"{ _authority}/protocol/openid-connect/token",
Code = n.Code,
if (tokenResponse.IsError)
throw new Exception(tokenResponse.Error);
var response = await client.GetUserInfoAsync(new UserInfoRequest
//Address = disco.UserInfoEndpoint,
Token = tokenResponse.IdentityToken,
Address = $"{ _authority}/protocol/openid-connect/userinfo",
//Code = n.Code,
//RedirectUri = _redirectUri
if (response.IsError)
throw new Exception(response.Error);
var claims = response.Claims;
n.AuthenticationTicket.Identity.AddClaims(claims);
