I want to retrieve a (resource owner password credentials flow) token with a specific client using org.keycloak.admin.client.Keycloak:
Keycloak keycloak = KeycloakBuilder.builder()
.serverUrl(AUTHSERVERURL)
.realm(realm)
.grantType(OAuth2Constants.CLIENT_CREDENTIALS)
.clientId(clientId)
.clientSecret(clientSecret).build();
as in this example by Thomas Darimont.
I added keycloak-admin-client to the SPI jar by copying it into the /modules directory of Keycloak (the image shows the directory structure of the Docker build job, that whole tree is copied into Docker when building the image).
Keycloak can find the module, but I keep running into a ClassNotFoundException: javax.ws.rs.client.Client
whenever that above code is run.
Iād think that keycloak-admin-client should be able to find it because jboss-jaxrs-api_2.1_spec-2.0.1Final
is provided by keycloak in /opt/jboss/keycloak/modules/system/layers/base/javax/ws/rs/api/main/
, but apparently not.
I tried adding the dependencies explicitly to the SPI pom.xml, as in this SO question , but I keep getting this:
2022-02-15 13:39:26,588 ERROR [org.keycloak.services.error.KeycloakErrorHandler] (default task-1) Uncaught server error: java.lang.NoClassDefFoundError: javax/ws/rs/client/Client
at deployment.europeana-eventlistener.jar//eu.europeana.keycloak.user.UserRemovedMessageHandler.getKCClient(UserRemovedMessageHandler.java:257)
Caused by: java.lang.ClassNotFoundException: javax.ws.rs.client.Client from [Module "org.keycloak.keycloak-admin-client" version 16.1.0 from local module loader @59cba5a (finder: local module finder @1bd39d3c (roots: /opt/jboss/keycloak/modules,/opt/jboss/keycloak/modules/system/layers/keycloak,/opt/jboss/keycloak/modules/system/layers/base))]
at org.jboss.modules.ModuleClassLoader.findClass(ModuleClassLoader.java:200)
Any ideas how to fix that?
