Hello community members,
Is there any way we can add the ‘memberOf’ attribute to the SAML response? Users are federated from LDAP server (read-only) mode to the Keycloak server.
Any help on this is much appreciated.
Thank you.
Thank you.
Hello! Did u find a solution for this? I have the same question
This requires two steps:
user-attribute-ldap-mapper
, map the memberOf
LDAP attribute to a User Model Attribute of your choice;User Attribute
, then map the user attribute to SAML attribute.Depending on you Keycloak version, you might need to define the custom attribute in Realm settings → User Profile.
