Hi. I’m looking for a way to move a few thousand user accounts to Keycloak. The system which currently holds the user data will be shut down after. If I understand correctly, this could be done with user federation (https://www.keycloak.org/docs/latest/server_admin/#_user-storage-federation) with a provider that stores all data in Keycloak’s database?
Some providers even import the user locally and sync periodically with the external store.
In the old system, the passwords were hashed with bcrypt. As far as I see, Keycloak doesn’t support bcrypt and a third-party plugin would be needed (https://github.com/leroyguillaume/keycloak-bcrypt). Is there a way around? For example, is it possible to import user data from federation upon login but take (and hash) the password as provided by the user?
I am by no means a Keycloak expert, but I may be facing a similar situation in the future. My thought was to simply extract the user data from the source database, transform and import it in the relevant locations directly in the Keycloak database with SQL… all but the password. Then outside of keycloak, send a mass email to the users advising them that a password reset is required and let them use the “Forgot password” functionality. If I can initiate a bulk password reset within Keycloak, even better.
Again, I haven’t tried or even investigated whether this is practical, but it seems like a reasonable place to start.
On top of my head is to create an user federation plugin and override only the isValid method: @Override
public boolean isValid(RealmModel realmModel, UserModel userModel, CredentialInput input) {
