We are running Keycloak 18.0.2 for some time now on Kubernetes with Postgres. To save costs, I’d like to migrate it to MySQL (while also upgrading Keycloak to a recent version).
So I exported the master realm by importing a dump of the database locally and by running "kc.sh export … " on my machine. The exported files seem ok so far.
Now, I’m wondering how to import these files into my new Keycloak+MySQL. I put the exported data into a kubernetes configmap and attached it through a volume to the Keycloak pod, which I start with the option “–import-realm”. The import starts, but the import strategy is IGNORE_EXISTING. Can anybody telle me how to change it to OVERWRITE_EXISTING?
The output I’m getting is:
2025-01-18 21:42:53,290 INFO [org.keycloak.exportimport.dir.DirImportProvider] (main) Importing from directory /opt/keycloak/bin/…/data/import
2025-01-18 21:42:53,294 INFO [org.keycloak.services] (main) KC-SERVICES0030: Full model import requested. Strategy: IGNORE_EXISTING
Made some progress:
I also installed mysql-server locally and ran the command “kc.sh import --dir” command. This seems to do an overwrite. But still, how would I do that in a Kubernetes environment?
Hello @ppaulis, you just have to change the pod container args. It should be something like this (for a pod, but very similar for a deployment):
apiVersion: v1
kind: Pod
spec:
containers:
- image: quay.io/keycloak/keycloak:26.1.0
args: ["import", "--dir", "/path/to/your/import_file"]
restartPolicy: Never # or "OnFailure " if you want the import to restart when it fails
quarkus.datasource.jdbc.driver is set to ‘org.h2.jdbcx.JdbcDataSource’ but it is build time fixed to ‘com.mysql.cj.jdbc.MysqlXADataSource’. Did you change the property quarkus.datasource.jdbc.driver after building the application?
2025-01-21 09:56:51,400 INFO [org.keycloak.quarkus.runtime.hostname.DefaultHostnameProvider] (main) Hostname settings: FrontEnd: https://xxxxxxxxxxxxxxxxxxxxx, Strict HTTPS: false, Path: , Strict BackChannel: false, Admin: , Port: -1, Proxied: true
2025-01-21 09:56:51,556 WARN [io.agroal.pool] (agroal-11) Datasource ‘’: No suitable driver found for jdbc:mysql://xxxxxxxxx.mysql.database.azure.com:3306/keycloak_staging?useSSL=false&characterEncoding=UTF-8
Is there a way to change this property in the given context (Kubernetes Deployment)?
Here’s the list of relevant env vars I’m currently using (terraform syntax):
env {
name = “KC_DB”
value = “mysql”
env {
name = “KC_DB_DRIVER”
value = “mysql”
env {
name = “KC_DB_URL”
value = “jdbc:mysql://${var.database_hostname}:3306/${var.database_name}?useSSL=false&characterEncoding=UTF-8”
When I do the import locally and then import the MySQL dump, I get the following when running Keycloak with “kc.sh star-dev”:
Updating the configuration and installing your custom providers, if any. Please wait.
ERROR: Failed to run ‘build’ command.
ERROR: io.quarkus.builder.BuildException: Build failure: Build failed due to errors
[error]: Build step org.keycloak.quarkus.deployment.KeycloakProcessor#checkJdbcDriver threw an exception: io.quarkus.runtime.configuration.ConfigurationException: Unable to find the JDBC driver (mysql). You need to install it.
If i’m not mistaken, MySQL is supported out-of-the-box?
Yes mySQL drivers are shipped with Keycloak (except oracle drivers) : (Configuring the database - Keycloak)
Regarding the error you get in kubernetes context, have you followed the recommandations about Running Keycloak in a container - Keycloak ? Do you use the official docker image (quay.io/keycloak/keycloak) or are you somehow deriving it or using another docker image ?
Sorry again, I’ve done some homework now on configuring Keycloak. I’m using now an optimized image and the MySQL connection now works. My procedure is the following:
Starting on an empty database a kubernetes pod with command “import --dir /path/to/import/dir”. This creates all 87 tables. Restart policy is “Never” to avoid running it multiple times (see logs below).
Removing the Pod and switching to a kubernetes deployment with command “start-dev”.
Logs from the single Pod are (I removed MySQL migration warnings) :
2025-01-21 17:08:24,748 ERROR [org.keycloak.quarkus.runtime.configuration.mappers.PropertyMappers] (main) Hostname v1 options [proxy] are still in use, please review your configuration
2025-01-21 17:08:28,478 INFO [org.keycloak.quarkus.runtime.storage.infinispan.CacheManagerFactory] (Thread-5) Starting Infinispan embedded cache manager
2025-01-21 17:08:28,710 INFO [org.infinispan.CONTAINER] (Thread-5) Virtual threads support enabled
2025-01-21 17:08:29,047 INFO [org.infinispan.CONTAINER] (Thread-5) ISPN000556: Starting user marshaller ‘org.infinispan.commons.marshall.ImmutableProtoStreamMarshaller’
2025-01-21 17:08:29,689 INFO [org.infinispan.transaction.lookup.JBossStandaloneJTAManagerLookup] (Thread-5) ISPN000107: Retrieving transaction manager Transaction: unknown
2025-01-21 17:08:30,176 INFO [org.keycloak.broker.provider.AbstractIdentityProviderMapper] (main) Registering class org.keycloak.broker.provider.mappersync.ConfigSyncEventListener
2025-01-21 17:10:38,347 WARN [io.agroal.pool] (main) Datasource ‘’: JDBC resources leaked: 2 ResultSet(s) and 0 Statement(s)
2025-01-21 17:10:38,735 INFO [org.keycloak.connections.infinispan.DefaultInfinispanConnectionProviderFactory] (main) Node name: node_433177, Site name: null
2025-01-21 17:10:39,086 INFO [org.keycloak.exportimport.dir.DirImportProvider] (main) Importing from directory /opt/keycloak/data/import
2025-01-21 17:10:39,096 INFO [org.keycloak.services] (main) KC-SERVICES0030: Full model import requested. Strategy: OVERWRITE_EXISTING > 2025-01-21 17:11:59,001 INFO [org.keycloak.exportimport.util.ImportUtils] (main) Realm ‘master’ imported > 2025-01-21 17:12:04,342 INFO [org.keycloak.exportimport.dir.DirImportProvider] (main) Imported users from /opt/keycloak/data/import/master-users-0.json > 2025-01-21 17:12:07,048 INFO [org.keycloak.exportimport.dir.DirImportProvider] (main) Imported users from /opt/keycloak/data/import/master-users-3.json > 2025-01-21 17:12:14,973 INFO [org.keycloak.exportimport.dir.DirImportProvider] (main) Imported users from /opt/keycloak/data/import/master-users-1.json > 2025-01-21 17:12:19,392 INFO [org.keycloak.exportimport.dir.DirImportProvider] (main) Imported users from /opt/keycloak/data/import/master-users-2.json
2025-01-21 17:12:21,083 WARN [io.agroal.pool] (main) Datasource ‘’: JDBC resources leaked: 1 ResultSet(s) and 0 Statement(s)
2025-01-21 17:12:21,085 INFO [com.arjuna.ats.jbossatx] (main) ARJUNA032014: Stopping transaction recovery manager
2025-01-21 17:12:21,113 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: Failed to start server in (nonserver) mode
2025-01-21 17:12:21,114 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: Script upload is disabled
2025-01-21 17:12:21,114 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) For more details run the same command passing the ‘–verbose’ option. Also you can use ‘–help’ to see the details about the usage of the particular command.
As mentionned above, Database tables have been created.
The logs say that the master-realm & users have also been imported. However, the resulting Keycloak instance is completely empty. No clients, no scopes, no users, etc.
I’m guessing, that I missed again some crucial part here?
Are you sure your Keycloak pod connects to your freshly populated database ? What does the logs of your Keycloak instance says (try verbose option as mentionned in the logs of your importer pod)?
To simplify the import/export process, you can use a Kubernetes Job instead of creating a pod an removing it by yourself.
Either the same process switches to another database provider (the local database? H2?) after having done the migrations in the MySQL database, or it executes the imports and fails to commit them to the MySQL database perhaps? Could it be related to transaction management somehow?
The behaviour is momstly the same… tables are created, and the import says that it was succesful, but nothing gets imported. However, a difference is, that locally, table names are all uppercase now :
Sorry, I’ve tried to reproduce localy but I don’t have any issue. Here are the steps I followed :
export realms by starting keycloak with the export command. As a result, I have one json file for the master realm and one for its users (this keycloak instance was using postgres db)
change the appropriate config to make keycloak use a freshly started mysql db (i’m using containers localy). Here are the config I’ve changed :
KC_DB=mysql
KC_DB_URL=jdbc:mysql://mysql-db-host:3306/testdb
start keycloak in start-dev mode (so I don’t need to rebuild an optimized image before run). The logs show that the database schema is created (even if I get warns about future deprecation during liquibase actions). Looking at the db after that : tables were created in uppercase, but that’s fine.
stop keycloak, and restart it using import command. Everything goes well. Looking at the db after that : data has been imported (clients, users, etc …)
run keycloak with start-dev mode : Keycloak uses the mysql db, and works fine (same as when it was using postgres).
Maybe step 3 is missing on your side (start keycloak with the empty mysql db so it creates the db objects like tables, constraints, etc, before running keycloak with the import command.
I must probably be doing wrong a simple, but crucial step…
I re-did all tests, also with a fresh export from my Postgres 26.1.0 installation. Both with a local installation on my Ubuntu machine and also with a docker compose setup :
I also enabled the query log on the MySQL container. In fact, all INSERTs are there (scopes, users, …) but it seems that they are not committed to the database. I see a lot of set autocommit=0 and set autocommit=1 and at the end there are rollback commands. I’ll investigate more in this direction.
If you still have it, could you perhaps copy paste your docker-compose file…? To make sure there aren’t any important differences?
Doing start-dev and and import separately doesn’t change the outcome.
Using MySQL 8.0 or 8.4 also changes nothing.
I can’t see any significant difference, but if you want, here is the compose file I’ve used for the test (just comment/uncomment the keycloak env variables depending on the database you want to plug to).
I also tried with your compose file, and had no issue with import, it works well.
I can import a new export containing only a some example data like a Realm role. My guess is then, that the problem lies somewhere in my exported data. I’ll try to empty it step by step, to see where it’s hanging.
It finally works now! The last missing piece was the “authorizationSettings” block in my export, which caused a “scrip upload is disabled” error during import. My guess is that this canceled the database transaction in the end. After removing this block, the import finished succesfully.
