I have read the document about Theme Selector Provider here. That page shows the way to implement the customized theme selector provider and deploy it to Keycloak but I cannot find any instruction to change the default theme selector to my customized theme selector.
So, how can I set my customized theme selector as the default theme selector for Keycloak?
Thank you for your answer. I already declared the configuration for my customized theme selector provider in standalone.xml but I cannot find where I can change the setting to use my theme selector provider. Could you give me some hints?
Besides that, I found a discussion that shows us the way to set the customized theme selector by default here. But I think it would be better if we use the official way that we can change the setting in the Keycloak UI.
