I am wondering how con remove the option to login with google from the username and password form.
Thank you in advance,
BR
BR
You can either delete the Google Identity Provider from the admin in “Identity Providers”. Or if you want to keep it and just make it invisible on the login page, you can go into the admin “Identity Providers”->“google”, enable “Hide on Login Page”, and click “Save”.
That’s correct!!
Thank you!
