I have Helm chart (https://github.com/codecentric/helm-charts/tree/master/charts/keycloak) config which looks like this:
keycloak:
basepath: auth/
username: admin
password: password
route:
tls:
enabled: false
extraEnv: |
value: "true"
- name: KEYCLOAK_IMPORT
value: keycloak/master-realm.json
- name: JAVA_OPTS
value: >-
-Djboss.socket.binding.port-offset=1000
extraVolumes: |
- name: realm-secret
secret:
secretName: realm-secret
extraVolumeMounts: |
mountPath: "keycloak"
readOnly: true
extraArgs: "-Dkeycloak.migration.action=import -Dkeycloak.migration.provider=dir -Dkeycloak.migration.dir=/keycloak -Dkeycloak.migration.strategy=IGNORE_EXISTING"
ingress:
enabled: true
annotations:
kubernetes.io/ingress.class: nginx
nginx.ingress.kubernetes.io/use-regex: "true"
path: /auth/?(.*)
hosts:
- keycloak.localtest.me
Where keycloak
is folder within where everything is located with master-realm.json
configs, where I set "sslRequired" : "NONE"
I’ve setted secret containing master-realm.json in my k8s cluster on creation like this:
kubectl create secret generic realm-secret --from-file=./keycloak/master-realm.json
And I see it there with:
$ kubectl describe secrets/realm-secret
Namespace: default
Labels: <none>
Annotations: <none>
Type: Opaque
Data
master-realm.json: 62288 bytes
But in my ingress controller I still see error and nothing works:
W0829 13:44:44.838998 7 controller.go:1387] Error getting SSL certificate "default/keycloak-tls": local SSL certificate default/keycloak-tls was not found
How do I disable this keycloak-tls?
Here how ingress looks like pastebin.com/PqE9akyg
