I would like to know if there is a conventional method to force a user to re-validate the terms and conditions? Indeed, it is expected to have a value of remember me high to prevent users from seeing connect each time. But how do you force users to validate the new terms if they change during this remember me period?
Try to set the “Required Action” of the T&C on the specific user(s) again. Then, they are forced to execute the required action, which is confirming the T&C again.
Before, you have to activate the Required Action itself, but I guess this is already done, otherwise your users couldn’t have agreed to T&Cs the first time:
There’s no setting to get this for all users. You’ll have to set it (programatically) on each user on it’s own.
Alternatively, you can implement an Authentication Provider to force setting the Required Action upon some custom conditions.
According to you, make sense to do that via an invalidation of the realm public key for that? Thus this action could force all users to login again and validate the terms again.
