Hi all
I use Keycloak to secure my apps and I have wrote a bash script, that makes an access token request via curl to the Keycloak server as follows:
#!/bin/bash
export KC_REALM=databaker
export KC_USERNAME=user1@example.io
export KC_PASSWORD=databaker
export KC_CLIENT=account
export KC_SERVER=localhost:8080
export KC_CONTEXT=auth
export KC_CLIENT_SECRET=9aac2131-1316-4d72-8f32-9d65cdc23a17
# Request Tokens for credentials
export KC_URL=http://$KC_SERVER/$KC_CONTEXT/realms/$KC_REALM/protocol/openid-connect/token
echo "URL => $KC_URL"
export KC_RESPONSE=$(
curl -X POST \
-H "content-type: application/x-www-form-urlencoded" \
-d "username=$KC_USERNAME" \
-d "password=$KC_PASSWORD" \
-d "grant_type=authorization_code" \
-d "client_id=$KC_CLIENT" \
-d "client_secret=$KC_CLIENT_SECRET" \
$KC_URL |
jq .
echo "$KC_RESPONSE"
if grep -q "error" <<< "$KC_RESPONSE"; then
echo "++++++++Error+++++++++"
exit 1
fi
export KC_ACCESS_TOKEN=$(echo $KC_RESPONSE | jq -r .access_token)
echo $KC_ACCESS_TOKEN
export SVC=http://localhost:9090/genders
export SVC_RES=$(curl \
-H "Authorization: Bearer $KC_ACCESS_TOKEN" \
-H "Accept: application/json" \
$SVC |
jq .)
echo $SVC_RES
Unfortunately, I do not receive any access token. The Keycloak responses with:
"error": "invalid_client",
"error_description": "Parameter client_assertion_type is missing"
The client account
is configured as follows:
The Keycloak OIDC JSON
"realm": "databaker",
"auth-server-url": "http://localhost:8080/auth/",
"ssl-required": "external",
"resource": "account",
"verify-token-audience": true,
"credentials": {
"secret-jwt": {
"secret": "9aac2131-1316-4d72-8f32-9d65cdc23a17"
"use-resource-role-mappings": true,
"confidential-port": 0
What am I doing wrong?
