I need some advice for this scenario. I think I’m missing some kind of Keycloak configuration or piece, or something.
I run a webapp and authenticate against Keycloak. Everything works fine. Then, I open a new tab, point to the same webapp and that bypasses the authentication and it’s automatically logged-in.
If I logout from one of them, the other one receives a “logout” event and can react to that event and also perform whatever logout actions may need.
So far so good. But, if I use the Keycloak UI to close the session instead of logging out from the webapp, neither of the 2 web apps are receiving the “logout” event and thus I can’t perform the webapp logout.
Am I missing something in the Keycloak configuration so that when I kill the session from Keycloak every single web application attached to that session gets that “logout” notification?
What I’m expecting is (on this scenario): if I kill the session from Keycloak, both web apps receive that “logout” event.
Has this something to do with the implementation of the backchannel logout feature?
Thanks in advance,
A.
