I’m using Keycloak inside docker and hosted on https://accounts.example.com
I’m using React as my client library and after login, the user goes into https://user.example.com
This React client uses .NET Core API located at https://api.user.example.com
I use keycloak.js
to manage access in React panel.
Now let’s say the user wants to create a ticket. I send this ticket info to the API:
title: 'Urgent backup',
priority: 'urgent',
description: 'Please backup my files immediately'
In our database, we have this design:
create table Tickets
Id bigint not null primary identity(1, 1),
UserGuid uniqueidentifier not null, -- How should I fill this column?
Title nvarchar(200) not null,
PriorityId int not null,
Description nvarchar(max) not null
The problem is, API should extract permanent data from the user.
I can’t store email
or username
in that column of course. And I can’t even rely on username
or email
because Keycloak’s admin panel allows this setting to be configured:
Thus the best option is to give the user a GUID
or UUID
in Keycloak and retrieve it in open id token.
I searched but I can’t find how to do this.
Can you help?
