How to import users to Keycloak DB from ADFS
Hi
I am trying to Integrate ADFS with Keycloak via Identity Providers-> SAML2.0
my question is, can we import user from ADFS to Keycloak Dabatase like we can do from LDAP+Keycloak Integration?
If above thing nor feasible in that case if i login in my web-app via Keycloak+ADFS user in that case, user will automatically import into the Keycloak DB or not?
, keycloak has the tendency to save it in its local DB
Not really sure what you are asking here, but users are by default imported into the Keycloak DB on first login with identity brokering.
