the kc server was initially set up using the default h2-db. Now we want to move the data into a MySQL-db. There are several posts about how to change the db as such used by keycloak from h2 to MySQL.
But I haven’t found detailed instructions how to MIGRATE the data from one system to the other. Does a simple export/import work?
If you can’t stop your instance (or won’t) add -Djboss.socket.binding.port-offset=111 to the export command (it basically starts new instance with same config but on ports shifted for 111)
