How to Restrict Identity Providers to Specific Client
Hello everyone, I’m using Keycloak 25.0.6 and I would like to know if it’s possible to restrict the display of identity providers to a specific client. I have the following setup: 1 realm and 3 clients (client1, client2, client3), and 2 identity providers (idp1 and idp2). I need the following outcome:
  • Client1 login should display the default Keycloak login and the option to log in via idp1
  • Client2 login should display the default Keycloak login and the option to log in via idp2
  • Client3 login should display only the default Keycloak login
I tried passing the following via query string during the app redirection to Keycloak: kc_idp_hint=idp1 for client1, kc_idp_hint=idp2 for client2, and kc_idp_hint='' for client3. However, all clients are showing both identity provider options.Does anyone know how I can achieve this result?
This scenario sounds more like you want to use different realms.
Each realm is one pool of users, clients are “client applications” that grant access to this user pool.
I considered this approach, but in my scenario, I might have users accessing more than one client. I want to avoid using multiple realms because, in my case, the number of realms could grow significantly, and I would still need to handle authentication of users from one realm in other realms. In my opinion, this management could become quite complex.
@bpedersen2, do you know if it’s possible to implement this use case the way I explained in the first post ? Or do you have any other idea on how I can achieve this without the downsides of using multiple realms?
