I’m wondering if its possible to run code on server startup, so that I can add server specific values which will be used for logging, for example to the MDC.
In our case I need to read some values from a config file on disk once on startup.
Is there a way to do this in a configurable fashion? I didn’t see anything SPI wise which seemed to fit this need and did search around for an hour or so but don’t have good leads on this one.
