How to use keycloak token to create Keycloak object in Angular
Hi All,
I have two scenarios in my website. My login can be done from normal login and from backend-initiated login.
When it is normal login, I can do login with the below code in my angular project,
keycloak = new Keycloak({
  url: environment.kc_url,
  realm: environment.kc_realm,
  clientId: environment.kc_client_id,
await this.keycloak
  .init({
    onLoad: 'login-required'
  .then(function () {
    // some code here
When it is a backend-initiated login, I have token already that is provided from the backend. So, I searched and found out that in the initOptions, token can be defined. So, I changed the code to,
await this.keycloak
  .init({
    token: 'access-token-here'
  .then(function () {
    // some code here
But it shows an error,
Failed to initialize adapter: TypeError: Cannot read properties of undefined (reading 'name')
Can anyone please help me to figure out what is wrong here or how to achieve what I am trying to do?
