Hi all
I am trying to make a request from a webapp to API service that is secure through Keycloak.
The API service has the following settings:
and it runs on Jetty with the following configurations:
jetty-web.xml
<!DOCTYPE Configure PUBLIC "-//Mort Bay Consulting//DTD Configure//EN" "http://www.eclipse.org/jetty/configure_9_0.dtd">
<Configure class="org.eclipse.jetty.webapp.WebAppContext">
<Get name="securityHandler">
<Set name="authenticator">
<New class="org.keycloak.adapters.jetty.KeycloakJettyAuthenticator">
<Set name="adapterConfig">
<New class="org.keycloak.representations.adapters.config.AdapterConfig">
<Set name="realm">databaker</Set>
<Set name="resource">user-svc</Set>
<Set name="authServerUrl">http://localhost:8080/auth/</Set>
<Set name="sslRequired">external</Set>
<Set name="bearerOnly">true</Set>
<Set name="confidentialPort">0</Set>
</New>
</Set>
</New>
</Set>
</Get>
</Configure>
and the web.xml
<web-app xmlns="http://java.sun.com/xml/ns/javaee" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://java.sun.com/xml/ns/javaee http://java.sun.com/xml/ns/javaee/web-app_3_0.xsd"
version="3.0">
<servlet>
<servlet-name>user-svc</servlet-name>
<servlet-class>io.databaker.UserSvcServlet</servlet-class>
<async-supported>true</async-supported>
</servlet>
<servlet-mapping>
<url-pattern>/*</url-pattern>
</servlet-mapping>
<security-constraint>
<web-resource-collection>
</web-resource-collection>
<auth-constraint>
<role-name>user</role-name>
</auth-constraint>
<user-data-constraint>
<transport-guarantee>NONE</transport-guarantee>
</user-data-constraint>
</security-constraint>
<login-config>
<auth-method>BASIC</auth-method>
<realm-name>databaker</realm-name>
</login-config>
<security-role>
</security-role>
</web-app>
The API service is running on http://localhost:9090
. When I make a request with the web app to the API service, it shows:
although the Authorization: Bearer
is giving:
Do I miss any configuration on Keycloak or what am I doing wrong?
Thanks
