Hi All,
I installed Keycloak using helm chart and created admin user using localhost UI. Now, when i try to load the auth/admin/master/console/ it fails (the page is blank) because all the URL’s are created using HTTP not HTTPS and I don’t even have the port 80 open. Looks like this:
<script type="text/javascript"> var authServerUrl = 'http://keycloak.myhost.com/auth'; var authUrl = 'http://keycloak.myhost.com/auth'; var consoleBaseUrl = '/auth/admin/master/console/'; var resourceUrl = '/auth/resources/k36of/admin/keycloak'; var masterRealm = 'master'; var resourceVersion = 'k36of'; </script>
How to make sure Keycloak uses https everywhere?
UPDATE: added env variable KEYCLOAK_FRONTEND_URL with https://keycloak.myhost.com/auth value and all good now.
