i need help to enable ssl in keycloak domain mode.
Check the documentation
https://www.keycloak.org/docs/latest/server_installation/index.html#_setting_up_ssl
@cric1… ya i was following the same documentation even i am getting the same error.
Is it worked for you in domain mode? as in standalone.xml it is working.
I have not checked with the domain mode.
okay i am actually doing keycloak clustering.
You can just put up a self signed cert or one from Lets Encrypt to overcome this.
Nope, not there but there is no reason why it should not work.
