Hi everyone,
I tested all the features I needed via http; works all good.
Now, using RootCA certificate, I modified keycloak.conf > kc.sh build > kc.sh start
The admin console login page seems fine.
It has the lock sign on the left of the url, and I can enter ID/PW to submit the form.
But when I submit the form, the log shows “Underlying input stream returned zero bytes”,
not allowing me to actually get in the console and modify the features I want.
This always happened in 17.0.0, 17.0.1, 18.0.0 version.
With 18.0.1 version, it sometimes allows me to access https and sometimes not.
(1) Is there any way I can completely fix this issue?
I’m also considering using http for keycloak admin/account console
(and us https for other clients)
So I tried
- “update REALM set ssl_required = ‘NONE’ where id = ‘master’;” in DB > NOT WORKING
- set “http-enabled=true” in conf > NOT WORKING
- added valid redirec_uri “http:///admin/master/console/*” in Clients (Master/security-admin-console) > NOT WORKING
It always redirected me to https login page for http:///admin…
(2) How can I disable https redirection only for admin and account console?
