Hi all,
I’m setting up a OIDC identity provider for SSO. I want to log the response of the /token call.
I’ve succeded by adding the config: /subsystem=logging/logger=org.apache.http.wire:add(level=DEBUG) which will log all outgoing HTTP Requests in Keycloak Server, but it generates unwanted logs.
I saw that for SAML there is a possibility to log the response by adding /subsystem=logging/logger=org.keycloak.saml:add(level=TRACE).
Is there a similar mechanism for OIDC?
