Setup
- Wildfly 26.0.1.Final
- Keycloak 16.1.1
I followed the instructions from the documentation for installing the WildFly adapter and used the following adapter:
https://github.com/keycloak/keycloak/releases/download/16.1.1/keycloak-oidc-wildfly-adapter-16.1.1.zip
Installation command
./bin/jboss-cli.sh --file=bin/adapter-elytron-install-offline.cli -Dserver.config=standalone-full.xml
web.xml
<web-app xmlns="http://java.sun.com/xml/ns/javaee"
xsi:schemaLocation="http://java.sun.com/xml/ns/javaee http://java.sun.com/xml/ns/javaee/web-app_3_0.xsd"
version="3.0">
<!-- Security configuration -->
<security-constraint>
<web-resource-collection>
<web-resource-name>admin-api</web-resource-name>
<url-pattern>/administration/*</url-pattern>
<url-pattern>/operations/*</url-pattern>
<url-pattern>/applications/*</url-pattern>
<url-pattern>/entities/*</url-pattern>
</web-resource-collection>
</security-constraint>
<login-config>
<auth-method>KEYCLOAK</auth-method>
<realm-name>this is ignored currently</realm-name>
</login-config>
<security-role>
<role-name>*</role-name>
</security-role>
</web-app>
I can also see the Keycloak subsystem in the standalone-full.xml
but when starting the application I get the following message:
java.lang.IllegalStateException: The required mechanism 'KEYCLOAK' is not available in mechanisms [BASIC, CLIENT_CERT, DIGEST, FORM] from the HttpAuthenticationFactory
I’m aware that the adapter is deprecated but according to this issue, it’s still possible to use.
