I am trying to implement logging into a device (a web browser for example) by scanning a QR code using your already logged in mobile device. The login flow for a typical end user would be the following:
- Log into your phone
- Start logging into a computer, it shows you a QR code.
- Scan the QR code with your phone
- The computer is automatically logged in.
WhatsApp Web for example works exactly like this.
I have done some research of how to accomplish this using Keycloak, and this is what I’ve discovered so far:
- At the time of writing, I’ve found no public libraries, blog posts, or documentation that help with the technical implementation details.
- I’ve found some mentions and similar implementations of QR login functionality (I would list them but new users can only put 2 links in a post)
- I’ve found a few possible implementation strategies to accomplish this, which I will list below.
Ideas
- The OIDC Device Flow seems to be very relevant.
- Can this be implemented in Keycloak?
- I see no way of enabling it by default, but perhaps it is possible to configure as an Authentication Flow?
- You could potentially implement it as a Keycloak Extension / Custom Authenticator, though this is more hands on than I’d prefer.
- You could somehow implement this manually using the API of existing flows, perhaps using Direct Grant or some more permissive flow
- This could be an ugly hack, what are the pitfalls?
I would greatly appreciate any input as to what to do and not to do. Links to relevant articles and other information would also help.
Best regards
