I am creating plugins (providers) for keycloak using the Service Provider Interface. I have been able to build a couple. Now I need to add the smallrye-graphql-client library to query a graphql server. However, the library is not found in the classpath when I deploy the pluging.
Questions
- Is it possible to still create a jar which includes the dependency library?
- If 1 is not possible, can it be done with a war?
- How can I add the library to the classpath. Preferably, that those are added together with the plugin instead of statically to Wildfly. I am using gradle. More details below.
Background Info
I succeeded to create a class and integration test for it. However, when I deploy the plugin to keycloak I get a the following error:
16:38:38,127 ERROR [org.keycloak.services.error.KeycloakErrorHandler] (default task-1)
Uncaught server error: java.util.ServiceConfigurationError: no
io.smallrye.graphql.client.typesafe.api.GraphQlClientBuilder in classpath
I have configured gradle to include the dependency that caused the problem and also add it to the classpath. I suspect that I should add an entry to the jboss-deployment-structure.xml but I don’t know what I should write there.
The gradle configuration
plugins {
id 'war'
id 'java-library'
id 'maven-publish'
repositories {
mavenLocal()
mavenCentral()
jcenter()
configurations {
dependenciesToInclude
dependencies {
dependenciesToInclude "io.smallrye:smallrye-graphql-client:1.0.20"
providedCompile group: 'javax.enterprise', name: 'cdi-api', version: '2.0'
providedCompile "org.keycloak:keycloak-server-spi:${keycloakVersion}"
providedCompile "org.keycloak:keycloak-server-spi-private:${keycloakVersion}"
providedCompile("org.keycloak:keycloak-services:${keycloakVersion}") {
exclude group: 'org.slf4j', module: 'slf4j-api'
exclude group: 'org.slf4j', module: 'slf4j-log4j12'
providedCompile group: 'org.keycloak', name: 'keycloak-model-api', version: '1.8.1.Final'
providedCompile "org.jboss.resteasy:resteasy-jaxrs"
providedCompile group: 'org.eclipse.microprofile.graphql', name: 'microprofile-graphql-api', version: '1.0.3'
compile group: 'org.apache.geronimo.config', name: 'geronimo-config-impl', version: '1.2.2'
configurations.compile.extendsFrom(configurations.dependenciesToInclude)
jar {
manifest {
attributes(
"Class-Path": configurations.dependenciesToInclude.collect { it.getName() }.join(' '))
from {
configurations.dependenciesToInclude.collect { it.isDirectory() ? it : zipTree(it) }
I unzip the jar file and this is how the manifest looks like
❯ cat META-INF/MANIFEST.MF ─╯
Manifest-Version: 1.0
Class-Path: smallrye-graphql-client-1.0.20.jar geronimo-config-impl-1.2.
2.jar smallrye-graphql-client-api-1.0.20.jar microprofile-graphql-api-1
.0.3.jar microprofile-config-api-1.3.jar org.osgi.annotation.versioning
-1.0.0.jar
Bellow is the jboss-deployment-structure.xml. There you can see my attempt to include the graphql library (commented out)
<jboss-deployment-structure>
<deployment>
<dependencies>
<module name="org.keycloak.keycloak-services"/>
<module name="org.keycloak.keycloak-saml-core-public"/>
<module name="org.apache.commons.codec"/>
<module name="org.apache.commons.lang"/>
<module name="org.jboss.logging"/>
<!-- <module name="io.smallrye.smallrye-graphql-client"/>-->
</dependencies>
</deployment>
</jboss-deployment-structure>
I am using Keycloak 11.0.2 (WildFly Core 12.0.3.Final)
