I have to integrate keycloak with obiee running on weblogic. I have read that there is no Keycloak adapter for WebLogic, and that i should use servlet filter (SAML in my case).
Have you got some examples or docs which can help me to implement it?
in the analytics.war of obiee 's weblogic, i did the following actions:
add filters in web.xml
add keycloak-saml.xml config file
and add keycloak-saml-servlet-filter-adapter-11.0.3.jar in the lib directory of ther war
Then i relaunch weblogic server and i have problems with missing class. So i add all dependancy jar of keycloak-saml-servlet-filter-adapter-11.0.3.jar in the lib directory of ther war.
But now i have the following error
weblogic.application.ModuleException: javax.xml.bind.JAXBException: ClassCastException: attempting to cast zip:/MIDDLE/SIMILO/i-milo-obiee.dev/config/domains/biplatform/servers/bi_server1/tmp/_WL_user/analytics/za01ic/war/WEB-INF/lib/jaxb-api-2.4.0-b180830.0359.jar!/javax/xml/bind/JAXBContext.class to jar:file:/usr/java/jdk-1.8/jre/lib/rt.jar!/javax/xml/bind/JAXBContext.class. Please make sure that you are specifying the proper ClassLoader.
at weblogic.application.internal.ExtensibleModuleWrapper.start(ExtensibleModuleWrapper.java:140)
So i think i have got conflicts between dependancies jar and weblogic jar.
Maybe i add too much jar dependancies.
How can i avoid this conflicts problems?
Does anyone has ever configured weblogic obiee as service provider site with keycloak as idp ?
I try with filters in analytics.ear with no success (see my previous message above), and now i’m trying to make it with SAML Authentication Provider configure on weblogic. But when i try to upload saml2 metadata xml file obtained through keycloak client/installation tab, i always get the following error message on weblogic admin console : The metadata is not an identity provider metadata.
