I got this error on the keyCloak, while trying to test configuration:
We are sorry…
An internal server error has occurred
Docker logs:
15:54:45,180 DEBUG [io.undertow.request] (default I/O-12) Matched prefix path /auth for path /auth/realms/master/protocol/saml/resolve
15:54:45,181 DEBUG [io.undertow.request.security] (default task-8) Attempting to authenticate /auth/realms/master/protocol/saml/resolve, authentication required: false
15:54:45,181 DEBUG [io.undertow.request.security] (default task-8) Authentication outcome was NOT_ATTEMPTED with method io.undertow.security.impl.CachedAuthenticatedSessionMechanism@431ad8b4 for /auth/realms/master/protocol/saml/resolve
15:54:45,181 DEBUG [io.undertow.request.security] (default task-8) Authentication result was ATTEMPTED for /auth/realms/master/protocol/saml/resolve
15:54:45,181 DEBUG [org.jboss.resteasy.resteasy_jaxrs.i18n] (default task-8) RESTEASY002315: PathInfo: /realms/master/protocol/saml/resolve
15:54:45,182 DEBUG [freemarker.cache] (default task-8) Couldn't find template in cache for "error.ftl"("en_US", UTF-8, parsed); will try to load it.
15:54:45,183 DEBUG [freemarker.cache] (default task-8) TemplateLoader.findTemplateSource("error_en_US.ftl"): Not found
15:54:45,183 DEBUG [freemarker.cache] (default task-8) TemplateLoader.findTemplateSource("error_en.ftl"): Not found
15:54:45,183 DEBUG [freemarker.cache] (default task-8) TemplateLoader.findTemplateSource("error.ftl"): Found
15:54:45,183 DEBUG [freemarker.cache] (default task-8) Loading template for "error.ftl"("en_US", UTF-8, parsed) from "file:/opt/jboss/keycloak/themes/base/login/error.ftl"
15:54:45,184 DEBUG [freemarker.cache] (default task-8) Couldn't find template in cache for "template.ftl"("en_US", UTF-8, parsed); will try to load it.
15:54:45,184 DEBUG [freemarker.cache] (default task-8) TemplateLoader.findTemplateSource("template_en_US.ftl"): Not found
15:54:45,184 DEBUG [freemarker.cache] (default task-8) TemplateLoader.findTemplateSource("template_en.ftl"): Not found
15:54:45,184 DEBUG [freemarker.cache] (default task-8) TemplateLoader.findTemplateSource("template.ftl"): Found
15:54:45,184 DEBUG [freemarker.cache] (default task-8) Loading template for "template.ftl"("en_US", UTF-8, parsed) from "file:/opt/jboss/keycloak/themes/base/login/template.ftl"
15:54:45,196 DEBUG [org.jboss.resteasy.resteasy_jaxrs.i18n] (default task-8) MessageBodyWriter: org.jboss.resteasy.spi.ResteasyProviderFactory$SortedKey
15:54:45,196 DEBUG [org.jboss.resteasy.resteasy_jaxrs.i18n] (default task-8) MessageBodyWriter: org.jboss.resteasy.plugins.providers.StringTextStar
15:54:45,196 DEBUG [org.jboss.resteasy.resteasy_jaxrs.i18n] (default task-8) Interceptor Context: org.jboss.resteasy.core.interception.ServerWriterInterceptorContext, Method : proceed
15:54:45,196 DEBUG [org.jboss.resteasy.resteasy_jaxrs.i18n] (default task-8) WriterInterceptor: org.jboss.resteasy.security.doseta.DigitalSigningInterceptor
15:54:45,196 DEBUG [org.jboss.resteasy.security.doseta.i18n] (default task-8) Interceptor : org.jboss.resteasy.security.doseta.DigitalSigningInterceptor, Method : aroundWriteTo
