Invalid_code when authenticating through load balancer
I’m trying to setup Keycloak for my company and have run into some issues that I can’t solve. I currently have keycloak installed on two servers in standalone clustered mode. I have these servers behind and external load balancer owned by another group. I’ve created two realms, one for Jenkins and one for Grafana. When I configure each of them to point directly to the server, it works with no problem. The issue comes into play when I try to authenticate through the load balanced url. Below are some logs from Keycloak, grafana and Jenksins.
Keycloak Log:
2020-02-19 06:30:19,599 WARN  [org.keycloak.events] (default task-1) type=CODE_TO_TOKEN_ERROR, realmId=CICD, clientId=grafana, userId=null, ipAddress=24.43.182.84, error=invalid_code, grant_type=authorization_code, code_id=08c751b6-d6a1-4b55-9f69-4b4c28c0c9c4, client_auth_method=client-secret
Grafana Log:
t=2020-02-19T14:32:09+0000 lvl=info msg="Request Completed" logger=context userId=0 orgId=0 uname= method=GET path=/login/generic_oauth status=302 remote_addr=172.23.0.5 time_ms=0 size=345 referer=https://domain.com/grafana/login
t=2020-02-19T14:32:52+0000 lvl=info msg="state check" logger=oauth queryState=0c5576040cb0984602e4e5a8ccc891e425065c740f9c6e4b3331494ad5c69b9b cookieState=0c5576040cb0984602e4e5a8ccc891e425065c740f9c6e4b3331494ad5c69b9b
t=2020-02-19T14:32:52+0000 lvl=eror msg=login.OAuthLogin(NewTransportWithCode) logger=context userId=0 orgId=0 uname= error="oauth2: cannot fetch token: 400 Bad Request\nResponse: {\"error\":\"invalid_grant\",\"error_description\":\"Code not valid\"}"
t=2020-02-19T14:32:52+0000 lvl=eror msg="Request Completed" logger=context userId=0 orgId=0 uname= method=GET path=/login/generic_oauth status=500 remote_addr=172.23.0.5 time_ms=21 size=1751 referer="https://load_balanced_domain.com/auth/realms/CICD/protocol/openid-connect/auth?access_type=online&client_id=grafana&redirect_uri=https%3A%2F%2Fdomain.com%2Fgrafana%2Flogin%2Fgeneric_oauth&response_type=code&scope=openid+email+profile&state=kyersRiz2wsAryohnLlZPPdtQjA6MJO8wanOnDaXgaY%3D"
Response from Jenkins:
com.google.api.client.auth.oauth2.TokenResponseException: 400 Bad Request
  "error" : "invalid_grant",
  "error_description" : "Code not valid"
Keycloak service:
[Unit]
Description=Keycloak
After=network.target
[Service]
Type=idle
User=keycloak
Group=keycloak
ExecStart=/opt/keycloak/current/bin/standalone.sh --server-config=standalone-ha.xml -b 0.0.0.0
TimeoutStartSec=600
TimeoutStopSec=600
[Install]
WantedBy=multi-user.target
Screenshots of my client setup within keycloak:
Another thing that might be worth pointing out is I’ve setup the keycloak servers behind a apache reverse proxy and pointed the load balancer to that, and I’ve taken apache out of the equation and had the load balancer point directly to the keycloak service on port 8443.
I’ve also verified from the team doing the load balancing that X-Forwarded-For and X-Forwarded-Proto are enabled and they are forwarding the client IP. If there are other settings to look for on the LB, let me know.
If anyone could help point me in the right direction that would be great! If there is a log that wasn’t included or a config that could help troubleshoot, please let me know.
I’m using the standalone-ha.xml file on both servers and they are configured the same
<?xml version='1.0' encoding='UTF-8'?>
<server xmlns="urn:jboss:domain:10.0">
    <extensions>
        <extension module="org.jboss.as.clustering.infinispan"/>
        <extension module="org.jboss.as.clustering.jgroups"/>
        <extension module="org.jboss.as.connector"/>
        <extension module="org.jboss.as.deployment-scanner"/>
        <extension module="org.jboss.as.ee"/>
        <extension module="org.jboss.as.ejb3"/>
        <extension module="org.jboss.as.jaxrs"/>
        <extension module="org.jboss.as.jmx"/>
        <extension module="org.jboss.as.jpa"/>
        <extension module="org.jboss.as.logging"/>
        <extension module="org.jboss.as.mail"/>
        <extension module="org.jboss.as.modcluster"/>
        <extension module="org.jboss.as.naming"/>
        <extension module="org.jboss.as.remoting"/>
        <extension module="org.jboss.as.security"/>
        <extension module="org.jboss.as.transactions"/>
        <extension module="org.jboss.as.weld"/>
        <extension module="org.keycloak.keycloak-server-subsystem"/>
        <extension module="org.wildfly.extension.bean-validation"/>
        <extension module="org.wildfly.extension.core-management"/>
        <extension module="org.wildfly.extension.elytron"/>
        <extension module="org.wildfly.extension.io"/>
        <extension module="org.wildfly.extension.microprofile.config-smallrye"/>
        <extension module="org.wildfly.extension.microprofile.health-smallrye"/>
        <extension module="org.wildfly.extension.microprofile.metrics-smallrye"/>
        <extension module="org.wildfly.extension.request-controller"/>
        <extension module="org.wildfly.extension.security.manager"/>
        <extension module="org.wildfly.extension.undertow"/>
    </extensions>
    <management>
        <security-realms>
            <security-realm name="ManagementRealm">
                <authentication>
                    <local default-user="$local" skip-group-loading="true"/>
                    <properties path="mgmt-users.properties" relative-to="jboss.server.config.dir"/>
                </authentication>
                <authorization map-groups-to-roles="false">
                    <properties path="mgmt-groups.properties" relative-to="jboss.server.config.dir"/>
                </authorization>
            </security-realm>
            <security-realm name="ApplicationRealm">
                <server-identities>
                    <ssl>
                        <keystore path="application.keystore" relative-to="jboss.server.config.dir" keystore-password="password" alias="server" key-password="password" generate-self-signed-certificate-host="localhost"/>
                    </ssl>
                </server-identities>
                <authentication>
                    <local default-user="$local" allowed-users="*" skip-group-loading="true"/>
                    <properties path="application-users.properties" relative-to="jboss.server.config.dir"/>
                </authentication>
                <authorization>
                    <properties path="application-roles.properties" relative-to="jboss.server.config.dir"/>
                </authorization>
            </security-realm>
        </security-realms>
        <audit-log>
            <formatters>
                <json-formatter name="json-formatter"/>
            </formatters>
            <handlers>
                <file-handler name="file" formatter="json-formatter" path="audit-log.log" relative-to="jboss.server.data.dir"/>
            </handlers>
            <logger log-boot="true" log-read-only="false" enabled="false">
                <handlers>
                    <handler name="file"/>
                </handlers>
            </logger>
        </audit-log>
        <management-interfaces>
            <http-interface security-realm="ManagementRealm">
                <http-upgrade enabled="true"/>
                <socket-binding http="management-http"/>
            </http-interface>
        </management-interfaces>
        <access-control provider="simple">
            <role-mapping>
                <role name="SuperUser">
                    <include>
                        <user name="$local"/>
                    </include>
                </role>
            </role-mapping>
        </access-control>
    </management>
    <profile>
        <subsystem xmlns="urn:jboss:domain:logging:8.0">
            <console-handler name="CONSOLE">
                <level name="INFO"/>
                <formatter>
                    <named-formatter name="COLOR-PATTERN"/>
                </formatter>
            </console-handler>
            <periodic-rotating-file-handler name="FILE" autoflush="true">
                <formatter>
                    <named-formatter name="PATTERN"/>
                </formatter>
                <file relative-to="jboss.server.log.dir" path="server.log"/>
                <suffix value=".yyyy-MM-dd"/>
                <append value="true"/>
            </periodic-rotating-file-handler>
            <logger category="com.arjuna">
                <level name="WARN"/>
            </logger>
            <logger category="io.jaegertracing.Configuration">
            </logger>
            <logger category="org.jboss.as.config">
                <level name="DEBUG"/>
            </logger>
            <logger category="sun.rmi">
            </logger>
            <root-logger>
                <handlers>
                    <handler name="CONSOLE"/>
                    <handler name="FILE"/>
                </handlers>
            </root-logger>
            <formatter name="PATTERN">
                <pattern-formatter pattern="%d{yyyy-MM-dd HH:mm:ss,SSS} %-5p [%c] (%t) %s%e%n"/>
            </formatter>
            <formatter name="COLOR-PATTERN">
                <pattern-formatter pattern="%K{level}%d{HH:mm:ss,SSS} %-5p [%c] (%t) %s%e%n"/>
            </formatter>
        </subsystem>
        <subsystem xmlns="urn:jboss:domain:bean-validation:1.0"/>
        <subsystem xmlns="urn:jboss:domain:core-management:1.0"/>
        <subsystem xmlns="urn:jboss:domain:datasources:5.0">
            <datasources>
                <datasource jndi-name="java:jboss/datasources/ExampleDS" pool-name="ExampleDS" enabled="true" use-java-context="true" statistics-enabled="${wildfly.datasources.statistics-enabled:${wildfly.statistics-enabled:false}}">
                    <connection-url>jdbc:h2:mem:test;DB_CLOSE_DELAY=-1;DB_CLOSE_ON_EXIT=FALSE</connection-url>
                    <driver>h2</driver>
                    <security>
                        <user-name>sa</user-name>
                        <password>sa</password>
                    </security>
                </datasource>
                <datasource jndi-name="java:jboss/datasources/KeycloakDS" pool-name="KeycloakDS" enabled="true" use-java-context="true" statistics-enabled="${wildfly.datasources.statistics-enabled:${wildfly.statistics-enabled:false}}">
                    <connection-url>jdbc:mariadb://example_db.com:3306/keycloak</connection-url>
                    <driver>mariadb</driver>
                    <security>
                        <user-name>keycloak</user-name>
                        <password>mydbpassword</password>
                    </security>
                </datasource>
                <drivers>
                    <driver name="h2" module="com.h2database.h2">
                        <xa-datasource-class>org.h2.jdbcx.JdbcDataSource</xa-datasource-class>
                    </driver>
                    <driver name="mariadb" module="org.mariadb">
                        <xa-datasource-class>org.mariadb.jdbc.MariaDbDataSource</xa-datasource-class>
                    </driver>
                </drivers>
            </datasources>
        </subsystem>
        <subsystem xmlns="urn:jboss:domain:deployment-scanner:2.0">
            <deployment-scanner path="deployments" relative-to="jboss.server.base.dir" scan-interval="5000" runtime-failure-causes-rollback="${jboss.deployment.scanner.rollback.on.failure:false}"/>
        </subsystem>
        <subsystem xmlns="urn:jboss:domain:ee:4.0">
            <spec-descriptor-property-replacement>false</spec-descriptor-property-replacement>
            <concurrent>
                <context-services>
                    <context-service name="default" jndi-name="java:jboss/ee/concurrency/context/default" use-transaction-setup-provider="true"/>
                </context-services>
                <managed-thread-factories>
                    <managed-thread-factory name="default" jndi-name="java:jboss/ee/concurrency/factory/default" context-service="default"/>
                </managed-thread-factories>
                <managed-executor-services>
                    <managed-executor-service name="default" jndi-name="java:jboss/ee/concurrency/executor/default" context-service="default" hung-task-threshold="60000" keepalive-time="5000"/>
                </managed-executor-services>
                <managed-scheduled-executor-services>
                    <managed-scheduled-executor-service name="default" jndi-name="java:jboss/ee/concurrency/scheduler/default" context-service="default" hung-task-threshold="60000" keepalive-time="3000"/>
                </managed-scheduled-executor-services>
            </concurrent>
            <default-bindings context-service="java:jboss/ee/concurrency/context/default" datasource="java:jboss/datasources/ExampleDS" managed-executor-service="java:jboss/ee/concurrency/executor/default" managed-scheduled-executor-service="java:jboss/ee/concurrency/scheduler/default" managed-thread-factory="java:jboss/ee/concurrency/factory/default"/>
        </subsystem>
        <subsystem xmlns="urn:jboss:domain:ejb3:6.0">
            <session-bean>
                <stateless>
                    <bean-instance-pool-ref pool-name="slsb-strict-max-pool"/>
                </stateless>
                <stateful default-access-timeout="5000" cache-ref="distributable" passivation-disabled-cache-ref="simple"/>
                <singleton default-access-timeout="5000"/>
            </session-bean>
            <pools>
                <bean-instance-pools>
                    <strict-max-pool name="mdb-strict-max-pool" derive-size="from-cpu-count" instance-acquisition-timeout="5" instance-acquisition-timeout-unit="MINUTES"/>
                    <strict-max-pool name="slsb-strict-max-pool" derive-size="from-worker-pools" instance-acquisition-timeout="5" instance-acquisition-timeout-unit="MINUTES"/>
                </bean-instance-pools>
            </pools>
            <caches>
                <cache name="simple"/>
                <cache name="distributable" passivation-store-ref="infinispan" aliases="passivating clustered"/>
            </caches>
            <passivation-stores>
                <passivation-store name="infinispan" cache-container="ejb" max-size="10000"/>
            </passivation-stores>
            <async thread-pool-name="default"/>
            <timer-service thread-pool-name="default" default-data-store="default-file-store">
                <data-stores>
                    <file-data-store name="default-file-store" path="timer-service-data" relative-to="jboss.server.data.dir"/>
                </data-stores>
            </timer-service>
            <remote connector-ref="http-remoting-connector" thread-pool-name="default">
                <channel-creation-options>
                    <option name="MAX_OUTBOUND_MESSAGES" value="1234" type="remoting"/>
                </channel-creation-options>
            </remote>
            <thread-pools>
                <thread-pool name="default">
                    <max-threads count="10"/>
                    <keepalive-time time="60" unit="seconds"/>
                </thread-pool>
            </thread-pools>
            <default-security-domain value="other"/>
            <default-missing-method-permissions-deny-access value="true"/>
            <statistics enabled="${wildfly.ejb3.statistics-enabled:${wildfly.statistics-enabled:false}}"/>
            <log-system-exceptions value="true"/>
        </subsystem>
        <subsystem xmlns="urn:jboss:domain:io:3.0">
            <worker name="default"/>
            <buffer-pool name="default"/>
        </subsystem>
        <subsystem xmlns="urn:jboss:domain:infinispan:9.0">
                <transport lock-timeout="60000"/>
                <local-cache name="realms">
                    <object-memory size="10000"/>
                </local-cache>
                <local-cache name="users">
                </local-cache>
                <distributed-cache name="sessions" owners="1"/>
                <distributed-cache name="authenticationSessions" owners="1"/>
                <distributed-cache name="offlineSessions" owners="1"/>
                <distributed-cache name="clientSessions" owners="1"/>
                <distributed-cache name="offlineClientSessions" owners="1"/>
                <distributed-cache name="loginFailures" owners="1"/>
                </local-cache>
                <replicated-cache name="work"/>
                <local-cache name="keys">
                    <object-memory size="1000"/>
                </local-cache>
                    <object-memory size="-1"/>
                    <expiration max-idle="-1" interval="300000"/>
                </distributed-cache>
            </cache-container>
            <cache-container name="server" aliases="singleton cluster" default-cache="default" module="org.wildfly.clustering.server">
                <replicated-cache name="default">
                    <transaction mode="BATCH"/>
                </replicated-cache>
            </cache-container>
            <cache-container name="web" default-cache="dist" module="org.wildfly.clustering.web.infinispan">
                <replicated-cache name="sso">
                    <locking isolation="REPEATABLE_READ"/>
                </replicated-cache>
                <distributed-cache name="dist">
                    <file-store/>
                <distributed-cache name="routing"/>
            </cache-container>
            <cache-container name="ejb" aliases="sfsb" default-cache="dist" module="org.wildfly.clustering.ejb.infinispan">
                    <file-store/>
            </cache-container>
            <cache-container name="hibernate" module="org.infinispan.hibernate-cache">
                <local-cache name="local-query">
                    <expiration max-idle="100000"/>
                </local-cache>
                <invalidation-cache name="entity">
                    <transaction mode="NON_XA"/>
                </invalidation-cache>
                <replicated-cache name="timestamps"/>
            </cache-container>
        </subsystem>
        <subsystem xmlns="urn:jboss:domain:jaxrs:1.0"/>
Second half of config file:
        <subsystem xmlns="urn:jboss:domain:jca:5.0">
            <archive-validation enabled="true" fail-on-error="true" fail-on-warn="false"/>
            <bean-validation enabled="true"/>
            <default-workmanager>
                <short-running-threads>
                    <core-threads count="50"/>
                    <queue-length count="50"/>
                    <max-threads count="50"/>
                    <keepalive-time time="10" unit="seconds"/>
                </short-running-threads>
                <long-running-threads>
                </long-running-threads>
            </default-workmanager>
            <cached-connection-manager/>
        </subsystem>
        <subsystem xmlns="urn:jboss:domain:jgroups:7.0">
            <channels default="ee">
                <channel name="ee" stack="udp" cluster="ejb"/>
            </channels>
            <stacks>
                <stack name="udp">
                    <transport type="UDP" socket-binding="jgroups-udp"/>
                    <protocol type="PING"/>
                    <protocol type="MERGE3"/>
                    <socket-protocol type="FD_SOCK" socket-binding="jgroups-udp-fd"/>
                    <protocol type="FD_ALL"/>
                    <protocol type="VERIFY_SUSPECT"/>
                    <protocol type="pbcast.NAKACK2"/>
                    <protocol type="UNICAST3"/>
                    <protocol type="pbcast.STABLE"/>
                    <protocol type="pbcast.GMS"/>
                    <protocol type="UFC"/>
                    <protocol type="MFC"/>
                    <protocol type="FRAG3"/>
                </stack>
                <stack name="tcp">
                    <transport type="TCP" socket-binding="jgroups-tcp"/>
                    <socket-protocol type="MPING" socket-binding="jgroups-mping"/>
                    <socket-protocol type="FD_SOCK" socket-binding="jgroups-tcp-fd"/>
                </stack>
            </stacks>
        </subsystem>
        <subsystem xmlns="urn:jboss:domain:jmx:1.3">
            <expose-resolved-model/>
            <expose-expression-model/>
            <remoting-connector/>
        </subsystem>
        <subsystem xmlns="urn:jboss:domain:jpa:1.1">
            <jpa default-datasource="" default-extended-persistence-inheritance="DEEP"/>
        </subsystem>
        <subsystem xmlns="urn:jboss:domain:mail:3.0">
            <mail-session name="default" jndi-name="java:jboss/mail/Default">
                <smtp-server outbound-socket-binding-ref="mail-smtp"/>
            </mail-session>
        </subsystem>
        <subsystem xmlns="urn:jboss:domain:modcluster:5.0">
            <proxy name="default" advertise-socket="modcluster" listener="ajp">
                <dynamic-load-provider>
                    <load-metric type="cpu"/>
                </dynamic-load-provider>
            </proxy>
        </subsystem>
        <subsystem xmlns="urn:jboss:domain:naming:2.0">
            <remote-naming/>
        </subsystem>
        <subsystem xmlns="urn:jboss:domain:remoting:4.0">
            <http-connector name="http-remoting-connector" connector-ref="default" security-realm="ApplicationRealm"/>
        </subsystem>
        <subsystem xmlns="urn:jboss:domain:request-controller:1.0"/>
        <subsystem xmlns="urn:jboss:domain:security-manager:1.0">
            <deployment-permissions>
                <maximum-set>
                    <permission class="java.security.AllPermission"/>
                </maximum-set>
            </deployment-permissions>
        </subsystem>
        <subsystem xmlns="urn:wildfly:elytron:8.0" final-providers="combined-providers" disallowed-providers="OracleUcrypto">
            <providers>
                <aggregate-providers name="combined-providers">
                    <providers name="elytron"/>
                    <providers name="openssl"/>
                </aggregate-providers>
                <provider-loader name="elytron" module="org.wildfly.security.elytron"/>
                <provider-loader name="openssl" module="org.wildfly.openssl"/>
            </providers>
            <audit-logging>
                <file-audit-log name="local-audit" path="audit.log" relative-to="jboss.server.log.dir" format="JSON"/>
            </audit-logging>
            <security-domains>
                <security-domain name="ApplicationDomain" default-realm="ApplicationRealm" permission-mapper="default-permission-mapper">
                    <realm name="ApplicationRealm" role-decoder="groups-to-roles"/>
                    <realm name="local"/>
                </security-domain>
                <security-domain name="ManagementDomain" default-realm="ManagementRealm" permission-mapper="default-permission-mapper">
                    <realm name="ManagementRealm" role-decoder="groups-to-roles"/>
                    <realm name="local" role-mapper="super-user-mapper"/>
                </security-domain>
            </security-domains>
            <security-realms>
                <identity-realm name="local" identity="$local"/>
                <properties-realm name="ApplicationRealm">
                    <users-properties path="application-users.properties" relative-to="jboss.server.config.dir" digest-realm-name="ApplicationRealm"/>
                    <groups-properties path="application-roles.properties" relative-to="jboss.server.config.dir"/>
                </properties-realm>
                <properties-realm name="ManagementRealm">
                    <users-properties path="mgmt-users.properties" relative-to="jboss.server.config.dir" digest-realm-name="ManagementRealm"/>
                    <groups-properties path="mgmt-groups.properties" relative-to="jboss.server.config.dir"/>
                </properties-realm>
            </security-realms>
            <mappers>
                <simple-permission-mapper name="default-permission-mapper" mapping-mode="first">
                    <permission-mapping>
                        <principal name="anonymous"/>
                        <permission-set name="default-permissions"/>
                    </permission-mapping>
                    <permission-mapping match-all="true">
                        <permission-set name="login-permission"/>
                </simple-permission-mapper>
                <constant-realm-mapper name="local" realm-name="local"/>
                <simple-role-decoder name="groups-to-roles" attribute="groups"/>
                <constant-role-mapper name="super-user-mapper">
                    <role name="SuperUser"/>
                </constant-role-mapper>
            </mappers>
            <permission-sets>
                <permission-set name="login-permission">
                    <permission class-name="org.wildfly.security.auth.permission.LoginPermission"/>
                </permission-set>
                <permission-set name="default-permissions">
                    <permission class-name="org.wildfly.extension.batch.jberet.deployment.BatchPermission" module="org.wildfly.extension.batch.jberet" target-name="*"/>
                    <permission class-name="org.wildfly.transaction.client.RemoteTransactionPermission" module="org.wildfly.transaction.client"/>
                    <permission class-name="org.jboss.ejb.client.RemoteEJBPermission" module="org.jboss.ejb-client"/>
                </permission-set>
            </permission-sets>
            <http>
                <http-authentication-factory name="management-http-authentication" security-domain="ManagementDomain" http-server-mechanism-factory="global">
                    <mechanism-configuration>
                        <mechanism mechanism-name="DIGEST">
                            <mechanism-realm realm-name="ManagementRealm"/>
                        </mechanism>
                    </mechanism-configuration>
                </http-authentication-factory>
                <provider-http-server-mechanism-factory name="global"/>
            </http>
            <sasl>
                <sasl-authentication-factory name="application-sasl-authentication" sasl-server-factory="configured" security-domain="ApplicationDomain">
                        <mechanism mechanism-name="JBOSS-LOCAL-USER" realm-mapper="local"/>
                        <mechanism mechanism-name="DIGEST-MD5">
                            <mechanism-realm realm-name="ApplicationRealm"/>
                        </mechanism>
                </sasl-authentication-factory>
                <sasl-authentication-factory name="management-sasl-authentication" sasl-server-factory="configured" security-domain="ManagementDomain">
                        </mechanism>
                <configurable-sasl-server-factory name="configured" sasl-server-factory="elytron">
                    <properties>
                        <property name="wildfly.sasl.local-user.default-user" value="$local"/>
                    </properties>
                </configurable-sasl-server-factory>
                <mechanism-provider-filtering-sasl-server-factory name="elytron" sasl-server-factory="global">
                    <filters>
                        <filter provider-name="WildFlyElytron"/>
                    </filters>
                </mechanism-provider-filtering-sasl-server-factory>
                <provider-sasl-server-factory name="global"/>
            </sasl>
        </subsystem>
        <subsystem xmlns="urn:jboss:domain:security:2.0">
            <security-domains>
                <security-domain name="other" cache-type="default">
                    <authentication>
                        <login-module code="Remoting" flag="optional">
                            <module-option name="password-stacking" value="useFirstPass"/>
                        </login-module>
                        <login-module code="RealmDirect" flag="required">
                        </login-module>
                    </authentication>
                </security-domain>
                <security-domain name="jboss-web-policy" cache-type="default">
                    <authorization>
                        <policy-module code="Delegating" flag="required"/>
                    </authorization>
                </security-domain>
                <security-domain name="jaspitest" cache-type="default">
                    <authentication-jaspi>
                        <login-module-stack name="dummy">
                            <login-module code="Dummy" flag="optional"/>
                        </login-module-stack>
                        <auth-module code="Dummy"/>
                    </authentication-jaspi>
                </security-domain>
                <security-domain name="jboss-ejb-policy" cache-type="default">
                    <authorization>
                    </authorization>
                </security-domain>
            </security-domains>
        </subsystem>
        <subsystem xmlns="urn:jboss:domain:transactions:5.0">
            <core-environment node-identifier="${jboss.tx.node.id:1}">
                <process-id>
                    <uuid/>
                </process-id>
            </core-environment>
            <recovery-environment socket-binding="txn-recovery-environment" status-socket-binding="txn-status-manager"/>
            <coordinator-environment statistics-enabled="${wildfly.transactions.statistics-enabled:${wildfly.statistics-enabled:false}}"/>
            <object-store path="tx-object-store" relative-to="jboss.server.data.dir"/>
        </subsystem>
        <subsystem xmlns="urn:jboss:domain:weld:4.0"/>
        <subsystem xmlns="urn:wildfly:microprofile-config-smallrye:1.0"/>
        <subsystem xmlns="urn:wildfly:microprofile-health-smallrye:2.0" security-enabled="false" empty-liveness-checks-status="${env.MP_HEALTH_EMPTY_LIVENESS_CHECKS_STATUS:UP}" empty-readiness-checks-status="${env.MP_HEALTH_EMPTY_READINESS_CHECKS_STATUS:UP}"/>
        <subsystem xmlns="urn:wildfly:microprofile-metrics-smallrye:2.0" security-enabled="false" exposed-subsystems="*" prefix="${wildfly.metrics.prefix:wildfly}"/>
        <subsystem xmlns="urn:jboss:domain:undertow:10.0" default-server="default-server" default-virtual-host="default-host" default-servlet-container="default" default-security-domain="other" statistics-enabled="${wildfly.undertow.statistics-enabled:${wildfly.statistics-enabled:false}}">
            <buffer-cache name="default"/>
            <server name="default-server">
                <ajp-listener name="ajp" socket-binding="ajp"/>
                <http-listener name="default" socket-binding="http" proxy-address-forwarding="true" redirect-socket="proxy-https"/>
                <https-listener name="https" socket-binding="https" security-realm="ApplicationRealm" enable-http2="true"/>
                <host name="default-host" alias="localhost">
                    <location name="/" handler="welcome-content"/>
                    <http-invoker security-realm="ApplicationRealm"/>
                </host>
            </server>
            <servlet-container name="default">
                <jsp-config/>
                <websockets/>
            </servlet-container>
            <handlers>
                <file name="welcome-content" path="${jboss.home.dir}/welcome-content"/>
            </handlers>
        </subsystem>
        <subsystem xmlns="urn:jboss:domain:keycloak-server:1.1">
            <web-context>auth</web-context>
            <providers>
                <provider>classpath:${jboss.home.dir}/providers/*</provider>
            </providers>
            <master-realm-name>master</master-realm-name>
            <scheduled-task-interval>900</scheduled-task-interval>
            <theme>
                <staticMaxAge>2592000</staticMaxAge>
                <cacheThemes>true</cacheThemes>
                <cacheTemplates>true</cacheTemplates>
                <dir>${jboss.home.dir}/themes</dir>
            </theme>
            <spi name="eventsStore">
                <provider name="jpa" enabled="true">
                    <properties>
                        <property name="exclude-events" value="[&quot;REFRESH_TOKEN&quot;]"/>
                    </properties>
                </provider>
            </spi>
            <spi name="userCache">
                <provider name="default" enabled="true"/>
            </spi>
            <spi name="userSessionPersister">
                <default-provider>jpa</default-provider>
            </spi>
            <spi name="timer">
                <default-provider>basic</default-provider>
            </spi>
            <spi name="connectionsHttpClient">
            </spi>
            <spi name="connectionsJpa">
                <provider name="default" enabled="true">
                    <properties>
                        <property name="dataSource" value="java:jboss/datasources/KeycloakDS"/>
                        <property name="initializeEmpty" value="true"/>
                        <property name="migrationStrategy" value="update"/>
                        <property name="migrationExport" value="${jboss.home.dir}/keycloak-database-update.sql"/>
                    </properties>
                </provider>
            </spi>
            <spi name="realmCache">
            </spi>
            <spi name="connectionsInfinispan">
                <default-provider>default</default-provider>
                    <properties>
                        <property name="cacheContainer" value="java:jboss/infinispan/container/keycloak"/>
                    </properties>
                </provider>
            </spi>
            <spi name="jta-lookup">
                <default-provider>${keycloak.jta.lookup.provider:jboss}</default-provider>
                <provider name="jboss" enabled="true"/>
            </spi>
            <spi name="publicKeyStorage">
                <provider name="infinispan" enabled="true">
                    <properties>
                        <property name="minTimeBetweenRequests" value="10"/>
                    </properties>
                </provider>
            </spi>
            <spi name="x509cert-lookup">
                <default-provider>${keycloak.x509cert.lookup.provider:default}</default-provider>
            </spi>
            <spi name="hostname">
                    <properties>
                        <property name="frontendUrl" value="${keycloak.frontendUrl:}"/>
                        <property name="forceBackendUrlToFrontendUrl" value="false"/>
                    </properties>
                </provider>
            </spi>
        </subsystem>
    </profile>
    <interfaces>
        <interface name="management">
            <inet-address value="${jboss.bind.address.management:127.0.0.1}"/>
        </interface>
        <interface name="private">
            <inet-address value="${jboss.bind.address.private:127.0.0.1}"/>
        </interface>
        <interface name="public">
            <inet-address value="${jboss.bind.address:127.0.0.1}"/>
        </interface>
    </interfaces>
    <socket-binding-group name="standard-sockets" default-interface="public" port-offset="${jboss.socket.binding.port-offset:0}">
        <socket-binding name="ajp" port="${jboss.ajp.port:8009}"/>
        <socket-binding name="http" port="${jboss.http.port:8080}"/>
        <socket-binding name="https" port="${jboss.https.port:8443}"/>
        <socket-binding name="jgroups-mping" interface="private" multicast-address="${jboss.default.multicast.address:230.0.0.4}" multicast-port="45700"/>
        <socket-binding name="jgroups-tcp" interface="private" port="7600"/>
        <socket-binding name="jgroups-tcp-fd" interface="private" port="57600"/>
        <socket-binding name="jgroups-udp" interface="private" port="55200" multicast-address="${jboss.default.multicast.address:230.0.0.4}" multicast-port="45688"/>
        <socket-binding name="jgroups-udp-fd" interface="private" port="54200"/>
        <socket-binding name="management-http" interface="management" port="${jboss.management.http.port:9990}"/>
        <socket-binding name="management-https" interface="management" port="${jboss.management.https.port:9993}"/>
        <socket-binding name="modcluster" multicast-address="${jboss.modcluster.multicast.address:224.0.1.105}" multicast-port="23364"/>
        <socket-binding name="txn-recovery-environment" port="4712"/>
        <socket-binding name="txn-status-manager" port="4713"/>
        <socket-binding name="proxy-https" port="443"/>
        <outbound-socket-binding name="mail-smtp">
            <remote-destination host="localhost" port="25"/>
        </outbound-socket-binding>
    </socket-binding-group>
</server>
Blind guess: that proxy is doing URL encoding, so it may change code, which is received by Keycloak.
@jangaraj Thanks for the input. When you say the proxy, I’m assuming you are talking about the load balancer and not the apache reverse proxy? Because it’s no longer configured behind the apache reverse proxy and the load balancer is pointing directly to the servers on port 8443.
What is loadbalancer here? Loadbalancing is usually done on L4 and proxying (URL encoding) on L7.
@jangaraj I’m not that familiar with the load balancing aspect as that is controlled by another group, but I believe we are using software load balancing with AVI.
Try to compare the code from the browser with the code from the logs behind “LB”.
@jangaraj thanks, I’ll do that tomorrow.
@jangaraj I did some more troubleshooting this morning and removed one of the servers from the load balancer and it worked with no problems. I’m guessing that because my servers are in different data centers they are not sharing the same session cache? Do you know if sticky sessions would resolve this or do I need to configure cross data center support with Infinispan?
Obviously. Solution is up to you. You known your infrastructure and risk which you are able to accept.
I got it working. The issue was with the clustering of the two nodes. I had to configure the jgroups to use TCP instead of UDP and added TCPPING.
                <channel name="ee" stack="tcp" cluster="ejb"/>
            </channels>
            <stacks>
                <stack name="udp">
                </stack>
                <stack name="tcp">
                    <protocol type="TCPPING">
                        <property name="initial_hosts">server1_IP[7600],server2_IP[7600]</property>
                        <property name="ergonomics">false</property>
                    </protocol>
                </stack>
            </stacks>
        </subsystem>
I then had to change the service to bind my private IP.
[Unit]
[Service]
Type=idle
User=keycloak
Group=keycloak
ExecStart=/opt/keycloak/current/bin/standalone.sh --server-config=standalone-ha.xml -b 0.0.0.0 -bprivate PRIVATEIP
TimeoutStartSec=600
TimeoutStopSec=600
[Install]
