I have a rest service in java that ask to keycloak a list of users.
This is the method:
@Override
public GridResponse<UserRepresentation> getFilterdRecords(String token, String azienda, String esercizio, MultivaluedMap<String, String> formParams) throws BssException {
GridRequest request = new GridRequest(formParams);
// interrogo gli utenti su keycloak che hanno il ruolo o i ruoli X Y Z
try {
return ResourceService.getUsers(KeycloakUtility.readRealmFromJson(), request);
} catch (Exception ex) {
LOG.log(Level.SEVERE, "Errore interrogazione utenti su keycloak", ex);
throw new BssException();
public static GridResponse<UserRepresentation> getUsers(Configuration conf, GridRequest request) throws Exception {
Keycloak keycloakClient = KeycloakUtility.getKeycloak(conf);
RealmResource realmResource = keycloakClient.realm(conf.getRealm());
UsersResource usersResouce = realmResource.users();
List<UserRepresentation> results = usersResouce.list(request.getFirst(), request.getPageSize());
Integer count = usersResouce.count();
GridResponse<UserRepresentation> response = new GridResponse<>(results, count.longValue(), null);
KeycloakUtility.logoutkeycloak(conf, keycloakClient);
return response;
the method works and the users are returned.
If I call it form the web and so the json serialization is required, i get the following exception:
java.io.NotSerializableException: org.keycloak.representations.idm.UserRepresentation
I’m using jackson. I need to create a Serializer or there is one in the libraries?
Or i’m doing some mistakes?
