I’m working on a JEE project, implementing REST APIs with JAX-RS. I’m using Wildfly v21 as my application server, while my project is running on http://localhost:8081(changed to get a different port from Keycloak). I’ve configurated it with Keycloak using the JBoss EAP/WildFly adapter, and it seems well configurated.
web.xml:
<security-constraint>
<web-resource-collection>
<web-resource-name>auth_prototype</web-resource-name>
<url-pattern>/api/*</url-pattern>
</web-resource-collection>
<auth-constraint>
<role-name>user</role-name>
</auth-constraint>
<user-data-constraint>
<transport-guarantee>CONFIDENTIAL</transport-guarantee>
</user-data-constraint>
</security-constraint>
<login-config>
<auth-method>KEYCLOAK</auth-method>
<realm-name>auth-proto-realm</realm-name>
</login-config>
<security-role>
<role-name>admin</role-name>
</security-role>
<security-role>
</security-role>
keycloak.json:
"realm": "auth-proto-realm",
"auth-server-url": "http://localhost:8080/auth/",
"ssl-required": "external",
"resource": "auth-proto-client",
"credentials": {
"secret": "secret"
"confidential-port": 0
The issue is whatever URI I put in Valid Redirect URIs I keep getting the error invalid redirect URIs or it keeps loading the page without success:
I’ve tried everything but nothing seems to work, are my configurations ok?
Thanks a lot
