KC ignores port configuration
Hi there.
I’m struggling to get an instance of keycloak I’m using for development to use https.
The instance, version 24.0.2, runs completely fine under HTTP on port 80, but any configuration I enable about HTTPS is simply ignored.
The current configuration I use is:
export DEBUG_PORT=*:8888;
export KC_HTTP_ENABLED=false
export KC_HTTPS_ENABLED=true
export KC_HTTP_PORT=80
export KC_HTTPS_PORT=8443
export KC_HOSTNAME="https://mydomain.com:8443"
export KC_HOSTNAME_ADMIN="https://mydomain.com:8443"
export KC_HOSTNAME_BACKCHANNEL_DYNAMIC=false
export KC_HOSTNAME_DEBUG=true
export KC_HOSTNAME_STRICT=false
export KC_LOG_LEVEL="INFO"
export KC_HTTPS_CERTIFICATE_FILE="/etc/letsencrypt/live/mydomain/fullchain.pem"
export KC_HTTPSCERTIFICATE_KEY_FILE="/etc/letsencrypt/live/mydomain.com/privkey.pem"
/data/keycloak-24.0.2/bin/kc.sh --config-file "/data/keycloak-24.0.2/conf/quarkus.conf" --verbose start-dev -DSKIP_PARSE_PERSISTENCE_XML=true --https-port 443
Which has even a redundant https-port in command line, but then:
$ netstat -tulpn | grep java
tcp6       0      0 :::45545                :::*                    LISTEN      830825/java
tcp6       0      0 127.0.0.1:44331         :::*                    LISTEN      830825/java
tcp6       0      0 :::80                   :::*                    LISTEN      830825/java
It listens on port 80, but the URL doesn’t work because it tries to load resources from https and “https” is not there to listen.
If I change the KC_HTTP_PORT, then it gets updated accordingly, but the HTTPS one is simply always ignored.
KC_HTTP_PORT=8080
tcp6       0      0 :::8080                   :::*                    LISTEN      830825/java
I’ve already tried to cancel and recreate the H2 DB without success.
Do you have any advice on how make it work?
Thank you
You life will be happier if you run Keycloak as Docker container [1] and even happier with Docker Compose [2]
[1] Docker - Keycloak
[2] keycloak-workshop-stepup-mfa-biometrics/docker-compose-idp.yml at main · embesozzi/keycloak-workshop-stepup-mfa-biometrics · GitHub
Thank you for your advice.
Unfortunately I cannot use docker on this host.
I have another instance running fine with docker, but in this case I really need to configure a “direct” installation.
probably don’t use start-dev, instead use build and start separatly.
I tried even this, without success.
It gives me an error about processing a request with java.io.E0FException and then it hangs (it even refuse to die, I need to kill it with -9.
Anyway I found out that if I specify the ports using command line intead of ENV variables it works well:
keycloak-24.0.2/bin/ks.sh --verbose --start-dev --hostname-strict-backchannel=false --hostname-debug=true --log-level=INFO --https-certificate-file=[...] --https-certificate-key-file=[...] --debug
Listening on : http://0.0.0.0:8080 and https://0.0.0.0:8443
I wonder why…
