I have two problems with Keycloak in a Kubernets cluster. We have 6 pods from Keycloak witch have a connection to a DB cluster.
We configure for user custom attributes. We mapping a few attributes to the client (we write the Attributes in the Token and the InfoUser).
In the Database i can see the Attributes, but we get not in all Token-Request or UserInfo-Request this attribute´s. We get or get not this - randomly and i can’t say why. All Keycloaks use the same database.
The other thing is, that the Keycloak Pod has sometimes Failure like this:
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by com.sun.mail.util.SocketFetcher
(jar:file:/opt/jboss/keycloak/modules/system/layers/base/javax/mail/api/main/jakarta.mail-1.6.4.jar!/)
to method sun.security.util.HostnameChecker.getInstance(byte)
WARNING: Please consider reporting this to the maintainers of com.sun.mail.util.SocketFetcher
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access
operations
WARNING: All illegal access operations will be denied in a future release
or
WARN [org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory] (ConnectionValidator)
IJ030027: Destroying connection that is not valid, due to the following exception:
org.mariadb.jdbc.MariaDbConnection@5ab3dd35: java.sql.SQLNonTransientConnectionException:
(conn=8011472) unexpected end of stream, read 0 bytes from 4 (socket was closed by server)
at org.mariadb.jdbc//org.mariadb.jdbc.internal.util.exceptions.ExceptionMapper.get(ExceptionMapper.java:241)
at
org.mariadb.jdbc//org.mariadb.jdbc.internal.util.exceptions.ExceptionMapper.getException(ExceptionMapper.java:164)
at org.mariadb.jdbc//org.mariadb.jdbc.MariaDbStatement.executeExceptionEpilogue(MariaDbStatement.java:258)
