I am using latest keycloak version 10.0.2 along with mysql8 and it is failing when started while updating the database. Below are the logs for the same.
ak container
2020-06-08 10:13:15.340Z INFO [ServerService T] o.k.c.i.DefaultInfinispanConnectionProvi {{}} Node name: pun1dt11351, Site name: null
2020-06-08 10:13:18.502Z INFO [ServerService T] o.k.c.j.u.l.LiquibaseJpaUpdaterProvider {{}} Initializing database schema. Using changelog META-INF/jpa-changelog-master.xml
2020-06-08 10:18:15.359Z WARN [Transaction Rea] c.a.a.arjuna {{}} ARJUNA012117: TransactionReaper::check timeout for TX 0:ffff0a2b0205:30337369:5eddc1e1:e in state RUN
2020-06-08 10:18:15.373Z WARN [Transaction Rea] c.a.a.arjuna {{}} ARJUNA012121: TransactionReaper::doCancellations worker Thread[Transaction Reaper Worker 0,5,main] successfully canceled TX 0:ffff0a2b0205:30337369:5eddc1e1:e
2020-06-08 10:18:17.050Z WARN [Transaction Rea] c.a.a.arjuna {{}} ARJUNA012117: TransactionReaper::check timeout for TX 0:ffff0a2b0205:30337369:5eddc1e1:11 in state RUN
2020-06-08 10:18:17.052Z WARN [Transaction Rea] c.a.a.arjuna {{}} ARJUNA012121: TransactionReaper::doCancellations worker Thread[Transaction Reaper Worker 0,5,main] successfully canceled TX 0:ffff0a2b0205:30337369:5eddc1e1:11
2020-06-08 10:18:18.002Z WARN [Transaction Rea] c.a.a.arjuna {{}} ARJUNA012117: TransactionReaper::check timeout for TX 0:ffff0a2b0205:30337369:5eddc1e1:14 in state RUN
2020-06-08 10:18:18.006Z WARN [Transaction Rea] c.a.a.arjuna {{}} ARJUNA012095: Abort of action id 0:ffff0a2b0205:30337369:5eddc1e1:14 invoked while multiple threads active within it.
2020-06-08 10:18:18.011Z WARN [Transaction Rea] c.a.a.arjuna {{}} ARJUNA012381: Action id 0:ffff0a2b0205:30337369:5eddc1e1:14 completed with multiple threads - thread ServerService Thread Pool – 68 was in progress with java.net.SocketInputStream.socketRead0(Native Method)
java.net.SocketInputStream.socketRead(SocketInputStream.java:116)
java.net.SocketInputStream.read(SocketInputStream.java:171)
java.net.SocketInputStream.read(SocketInputStream.java:141)
com.mysql.cj.protocol.ReadAheadInputStream.fill(ReadAheadInputStream.java:107)
com.mysql.cj.protocol.ReadAheadInputStream.readFromUnderlyingStreamIfNecessary(ReadAheadInputStream.java:150)
com.mysql.cj.protocol.ReadAheadInputStream.read(ReadAheadInputStream.java:180)
java.io.FilterInputStream.read(FilterInputStream.java:133)
com.mysql.cj.protocol.FullReadInputStream.readFully(FullReadInputStream.java:64)
com.mysql.cj.protocol.a.SimplePacketReader.readHeader(SimplePacketReader.java:63)
com.mysql.cj.protocol.a.SimplePacketReader.readHeader(SimplePacketReader.java:45)
com.mysql.cj.protocol.a.TimeTrackingPacketReader.readHeader(TimeTrackingPacketReader.java:52)
com.mysql.cj.protocol.a.TimeTrackingPacketReader.readHeader(TimeTrackingPacketReader.java:41)
com.mysql.cj.protocol.a.MultiPacketReader.readHeader(MultiPacketReader.java:54)
com.mysql.cj.protocol.a.MultiPacketReader.readHeader(MultiPacketReader.java:44)
com.mysql.cj.protocol.a.NativeProtocol.readMessage(NativeProtocol.java:535)
com.mysql.cj.protocol.a.NativeProtocol.checkErrorMessage(NativeProtocol.java:711)
com.mysql.cj.protocol.a.NativeProtocol.sendCommand(NativeProtocol.java:650)
com.mysql.cj.protocol.a.NativeProtocol.sendQueryPacket(NativeProtocol.java:949)
com.mysql.cj.protocol.a.NativeProtocol.sendQueryString(NativeProtocol.java:895)
com.mysql.cj.NativeSession.execSQL(NativeSession.java:1111)
com.mysql.cj.jdbc.StatementImpl.executeInternal(StatementImpl.java:724)
com.mysql.cj.jdbc.StatementImpl.execute(StatementImpl.java:648)
org.jboss.jca.adapters.jdbc.WrappedStatement.execute(WrappedStatement.java:198)
liquibase.executor.jvm.JdbcExecutor$ExecuteStatementCallback.doInStatement(JdbcExecutor.java:307)
liquibase.executor.jvm.JdbcExecutor.execute(JdbcExecutor.java:55)
liquibase.executor.jvm.JdbcExecutor.execute(JdbcExecutor.java:113)
liquibase.database.AbstractJdbcDatabase.execute(AbstractJdbcDatabase.java:1277)
liquibase.database.AbstractJdbcDatabase.executeStatements(AbstractJdbcDatabase.java:1259)
liquibase.changelog.ChangeSet.execute(ChangeSet.java:582)
liquibase.changelog.visitor.UpdateVisitor.visit(UpdateVisitor.java:51)
liquibase.changelog.ChangeLogIterator.run(ChangeLogIterator.java:79)
liquibase.Liquibase.update(Liquibase.java:214)
liquibase.Liquibase.update(Liquibase.java:192)
liquibase.Liquibase.update(Liquibase.java:188)
org.keycloak.connections.jpa.updater.liquibase.LiquibaseJpaUpdaterProvider.updateChangeSet(LiquibaseJpaUpdaterProvider.java:182)
org.keycloak.connections.jpa.updater.liquibase.LiquibaseJpaUpdaterProvider.update(LiquibaseJpaUpdaterProvider.java:102)
org.keycloak.connections.jpa.updater.liquibase.LiquibaseJpaUpdaterProvider.update(LiquibaseJpaUpdaterProvider.java:81)
org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory$2.run(DefaultJpaConnectionProviderFactory.java:341)
org.keycloak.models.utils.KeycloakModelUtils.runJobInTransaction(KeycloakModelUtils.java:227)
org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.update(DefaultJpaConnectionProviderFactory.java:334)
org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.migration(DefaultJpaConnectionProviderFactory.java:306)
org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.lambda$lazyInit$0(DefaultJpaConnectionProviderFactory.java:182)
org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory$$Lambda$858/1044540519.run(Unknown Source)
org.keycloak.models.utils.KeycloakModelUtils.suspendJtaTransaction(KeycloakModelUtils.java:682)
org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.lazyInit(DefaultJpaConnectionProviderFactory.java:133)
org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.create(DefaultJpaConnectionProviderFactory.java:81)
org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.create(DefaultJpaConnectionProviderFactory.java:59)
org.keycloak.services.DefaultKeycloakSession.getProvider(DefaultKeycloakSession.java:204)
org.keycloak.models.jpa.JpaRealmProviderFactory.create(JpaRealmProviderFactory.java:51)
org.keycloak.models.jpa.JpaRealmProviderFactory.create(JpaRealmProviderFactory.java:33)
org.keycloak.services.DefaultKeycloakSession.realmLocalStorage(DefaultKeycloakSession.java:157)
org.keycloak.models.cache.infinispan.RealmCacheSession.getRealmDelegate(RealmCacheSession.java:148)
org.keycloak.models.cache.infinispan.RealmCacheSession.getMigrationModel(RealmCacheSession.java:141)
org.keycloak.migration.MigrationModelManager.migrate(MigrationModelManager.java:97)
org.keycloak.services.resources.KeycloakApplication.migrateModel(KeycloakApplication.java:244)
org.keycloak.services.resources.KeycloakApplication.migrateAndBootstrap(KeycloakApplication.java:185)
org.keycloak.services.resources.KeycloakApplication$1.run(KeycloakApplication.java:147)
org.keycloak.services.resources.KeycloakApplication.startup(KeycloakApplication.java:138)
org.keycloak.services.resources.KeycloakApplication$$Lambda$834/704250421.run(Unknown Source)
org.keycloak.provider.wildfly.WildflyPlatform.onStartup(WildflyPlatform.java:29)
org.keycloak.services.resources.KeycloakApplication.(KeycloakApplication.java:125)
sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
java.lang.reflect.Constructor.newInstance(Constructor.java:423)
org.jboss.resteasy.core.ConstructorInjectorImpl.construct(ConstructorInjectorImpl.java:152)
org.jboss.resteasy.spi.ResteasyProviderFactory.createProviderInstance(ResteasyProviderFactory.java:2805)
org.jboss.resteasy.spi.ResteasyDeployment.createApplication(ResteasyDeployment.java:369)
org.jboss.resteasy.spi.ResteasyDeployment.startInternal(ResteasyDeployment.java:281)
org.jboss.resteasy.spi.ResteasyDeployment.start(ResteasyDeployment.java:92)
org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.init(ServletContainerDispatcher.java:119)
org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.init(HttpServletDispatcher.java:36)
io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:117)
org.wildfly.extension.undertow.security.RunAsLifecycleInterceptor.init(RunAsLifecycleInterceptor.java:78)
io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:103)
io.undertow.servlet.core.ManagedServlet$DefaultInstanceStrategy.start(ManagedServlet.java:305)
io.undertow.servlet.core.ManagedServlet.createServlet(ManagedServlet.java:145)
io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:585)
io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:556)
io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:42)
io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction$$Lambda$790/429250079.call(Unknown Source)
org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1541)
org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction$$Lambda$791/103393049.call(Unknown Source)
io.undertow.servlet.core.DeploymentManagerImpl.start(DeploymentManagerImpl.java:598)
org.wildfly.extension.undertow.deployment.UndertowDeploymentService.startContext(UndertowDeploymentService.java:97)
org.wildfly.extension.undertow.deployment.UndertowDeploymentService$1.run(UndertowDeploymentService.java:78)
java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
java.util.concurrent.FutureTask.run(FutureTask.java:266)
org.jboss.threads.ContextClassLoaderSavingRunnable.run(ContextClassLoaderSavingRunnable.java:35)
org.jboss.threads.EnhancedQueueExecutor.safeRun(EnhancedQueueExecutor.java:1982)
org.jboss.threads.EnhancedQueueExecutor$ThreadBody.doRunTask(EnhancedQueueExecutor.java:1486)
org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1377)
java.lang.Thread.run(Thread.java:748)
org.jboss.threads.JBossThread.run(JBossThread.java:485)
2020-06-08 10:18:18.060Z WARN [Transaction Rea] c.a.a.arjuna {{}} ARJUNA012108: CheckedAction::check - atomic action 0:ffff0a2b0205:30337369:5eddc1e1:14 aborting with 1 threads active!
2020-06-08 10:18:18.061Z WARN [Transaction Rea] c.a.a.arjuna {{}} ARJUNA012121: TransactionReaper::doCancellations worker Thread[Transaction Reaper Worker 0,5,main] successfully canceled TX 0:ffff0a2b0205:30337369:5eddc1e1:14
2020-06-08 10:18:18.339Z WARN [ServerService T] c.a.a.arjuna {{}} ARJUNA012077: Abort called on already aborted atomic action 0:ffff0a2b0205:30337369:5eddc1e1:14
2020-06-08 10:18:18.340Z WARN [ServerService T] c.a.a.arjuna {{}} ARJUNA012077: Abort called on already aborted atomic action 0:ffff0a2b0205:30337369:5eddc1e1:11
2020-06-08 10:18:18.342Z WARN [ServerService T] c.a.a.arjuna {{}} ARJUNA012077: Abort called on already aborted atomic action 0:ffff0a2b0205:30337369:5eddc1e1:e
2020-06-08 10:18:18.342Z FATAL [ServerService T] o.k.services {{}} java.lang.RuntimeException: Failed to update database
2020-06-08 10:18:18.344Z INFO [ Thread-2] o.j.a.server {{}} WFLYSRV0220: Server shutdown has been requested via an OS signal
the datasource configuration in standalone.xml is as below:
connection url : jdbc:mysql://localhost:3306/keycloak?useSSL=false&allowPublicKeyRetrieval=true&connectTimeout=300000&characterEncoding=UTF-8
driver: mysql
pool:
min-pool-size 10
max-pool-size 30
security
username: keycloak
password : keycloak
validation:
valid-connection-checker class-name
validate-on-match: true
exception-sorter class-name:
timeout:
idle-timeout-minutes 100
statement
track-statements true
And the driver definition in standalone.xml is as below:
(driver name= mysql module = com.mysql)
com.mysql.cj.jdbc.MysqlXADataSource (xa-datasource-class com.mysql.cj.jdbc.MysqlXADataSource)
Database created as below:
Did someone faced this issue and figured out the resolution for this?
Thanks in Advance
