Steps to Reproduce
Set up a SAML client with Keycloak as IDP in 11.0.3
Try to login with the user and pass kc_locale=de or any enabled language that is not English.
The login page appears in English, instead of the given locale.
We have used this to redirect users in Keycloak 6.0.1 to the localized login page, but this is not working anymore in 11.0.3 . Instead it shows a language dropout and whole page is in English.
Iâm running into this issue as well, also on 11.0.3. This appears to also apply to the âui_localesâ query parameter.
The cookie KEYCLOAK_LOCALE and the request header Accept-Language both work when Iâm debugging via postman, but neither of these can be set from the requesting application.
I have also tested this also on 12.0.2 and know the request parameters are still not working; both for SP initiated and IDP initiated URLs for SAML.
Iâve gone through the versions to find out when this behavior changed. 8.0.2 respects the query parameters, but 9.0.0 on donât.
I did a workaround that fixed this issue
at template.ftl a class="${properties.kcLocaleItemClass!}" href="${l.url}">${l.label} /a
instead of changing the href to l.locale
i added onClick event and then passed a function that sets a cookie for the selected language before changing href to l.url
li class=âkc-dropdown-itemâ><a tabindex=â0â onclick=âchangeLocale(${l.label}, ${l.url})â ${l.label} /a /li
