Hello Keycloak experts,
I’m looking for feedback about the KEYCLOAK-13160 Add support for Privacy Preserving Logging
PR: KEYCLOAK-13160 Add support for Privacy Preserving Logging by thomasdarimont · Pull Request #7180 · keycloak/keycloak · GitHub
JIRA: https://issues.redhat.com/browse/KEYCLOAK-13160
- What needs regarding to privacy and logging do you have?
- Do you need to exclude data from the log or would it be fine to mask / anonymize / encrypt the sensitive value?
- Which sensitive values would you need to anonymize?
- Would you use the suggested anonymization feature?
- Would you use the suggested SPI to add your own PrivacyProvider implementation?
- Do you miss something in the suggested implementation?
I’d love to hear your feedback
Cheers,
Thomas
