Hi All,
I’m getting an error while build the image. The error message is:
ERROR [org.jboss.as.controller] (Controller Boot Thread) WFLYCTL0056: Could not rename /opt/jboss/keycloak/standalone/configuration/standalone_xml_history/current to /opt/jboss/keycloak/standalone/configuration/standalone_xml_history/20220118-173011880: java.nio.file.DirectoryNotEmptyException: /opt/jboss/keycloak/standalone/configuration/standalone_xml_history/current
at java.base/sun.nio.fs.UnixCopyFile.ensureEmptyDir(UnixCopyFile.java:384)
at java.base/sun.nio.fs.UnixCopyFile.move(UnixCopyFile.java:484)
at java.base/sun.nio.fs.UnixFileSystemProvider.move(UnixFileSystemProvider.java:267)
at java.base/java.nio.file.Files.move(Files.java:1422)
at org.jboss.as.controller@18.0.0.Final//org.jboss.as.controller.persistence.ConfigurationFile.forcedMove(ConfigurationFile.java:807)
at org.jboss.as.controller@18.0.0.Final//org.jboss.as.controller.persistence.ConfigurationFile.createHistoryDirectory(ConfigurationFile.java:689)
at org.jboss.as.controller@18.0.0.Final//org.jboss.as.controller.persistence.ConfigurationFile.successfulBoot(ConfigurationFile.java:532)
at org.jboss.as.controller@18.0.0.Final//org.jboss.as.controller.persistence.BackupXmlConfigurationPersister.successfulBoot(BackupXmlConfigurationPersister.java:95)
at org.jboss.as.controller@18.0.0.Final//org.jboss.as.controller.AbstractControllerService.finishBoot(AbstractControllerService.java:588)
at org.jboss.as.server@18.0.0.Final//org.jboss.as.server.ServerService.finishBoot(ServerService.java:446)
at org.jboss.as.server@18.0.0.Final//org.jboss.as.server.ServerService.boot(ServerService.java:416)
at org.jboss.as.controller@18.0.0.Final//org.jboss.as.controller.AbstractControllerService$1.run(AbstractControllerService.java:424)
Could someone please help me with this issue?
Kind Regards,
Kumar
