I have tried the following Docker image and the download zip of version 17.0.0 and I get the same results
On using the URL http://localhost:8080/auth/admin I get a “page not found” message.
Note: this is not https
Here is the log file when the error occurs…
2022-02-17 12:57:52,619 DEBUG [org.keycloak.transaction.JtaTransactionWrapper] (executor-thread-3) new JtaTransactionWrapper
2022-02-17 12:57:52,619 DEBUG [org.keycloak.transaction.JtaTransactionWrapper] (executor-thread-3) was existing? false
2022-02-17 12:57:52,620 DEBUG [org.keycloak.services.error.KeycloakErrorHandler] (executor-thread-3) Error response 404: javax.ws.rs.NotFoundException: RESTEASY003210: Could not find resource for full path: http://localhost:8080/auth/admin
at org.jboss.resteasy.core.registry.SegmentNode.match(SegmentNode.java:152)
at org.jboss.resteasy.core.registry.RootNode.match(RootNode.java:74)
at org.jboss.resteasy.core.registry.RootClassNode.match(RootClassNode.java:47)
at org.jboss.resteasy.core.ResourceMethodRegistry.getResourceInvoker(ResourceMethodRegistry.java:480)
at org.jboss.resteasy.core.SynchronousDispatcher.getInvoker(SynchronousDispatcher.java:332)
at org.jboss.resteasy.core.SynchronousDispatcher.lambda$invoke$4(SynchronousDispatcher.java:253)
at io.quarkus.vertx.http.runtime.VertxHttpRecorder$5.handle(VertxHttpRecorder.java:362)
at io.quarkus.vertx.http.runtime.VertxHttpRecorder$5.handle(VertxHttpRecorder.java:340)
at org.keycloak.quarkus.runtime.integration.web.QuarkusRequestFilter.lambda$createBlockingHandler$1(QuarkusRequestFilter.java:66)
2022-02-17 12:57:52,625 DEBUG [freemarker.cache] (executor-thread-3) Couldn't find template in cache for "error.ftl"("en_GB", UTF-8, parsed); will try to load it.
2022-02-17 12:57:52,625 DEBUG [freemarker.cache] (executor-thread-3) TemplateLoader.findTemplateSource("error_en_GB.ftl"): Not found
I have started the service via this command…
./kc.sh start-dev --log-level=DEBUG
Version: keycloak-17.0.0.zip
Any ideas on how to resolve this?
Thanks
Jeff
I have just found the following bug raised:
